Packing a Caravan safely and securely
Submitted: Tuesday, Aug 05, 2008 at 19:55
ThreadID: 60514 Views:7907 Replies:3 FollowUps:1
Related Pages
Hi to all! I am new to this site and lifestlye. My husband, 2 girls ages 13 and 15 are looking at heading off around Australia. we have a 99 Landrover Discovery Petrol with Roadstar Dreamtime (family) van. I Would appreciate any advice gained from your experiences as to how to keep things in the one place in the van. Useful tips are more than welcome.
Cheers Kez.
Reply By: Notso - Tuesday, Aug 05, 2008 at 21:01
Line all your cupboard shelves with that bubbly rubberised sheeting.
Put Glassware, if you take any in stubby holders. Even plastic glasses otherwise they scratch like blazes.
Buy Corelle crockery it's more robust, and lighter.
Make sure you don't put too much weight in the front boot. Most of em say around 30 Kilos, but I've seen people with a hundred kilos or more.
Check your Ball weight and total van weight when you have it loaded. Don't rely on the figures you have on the compliance plate as most of em are wrong. Use a local public weigh bridge
If I think of anything else I'll add it in.
AnswerID: 319257
Reply By: Member - Willie , Sydney. - Wednesday, Aug 06, 2008 at 07:41
Non-stick frypans and saucepans are great in caravans , to cut down the cleaning . BUT , stacking them scratches and ruins the non-stick surface .
I purchased a cheap , thin ( about 1.5 cm ) closed cell foam camping matt from Clarke Rubber ( about $12 ) .
I cut a round piece to fit the inside of the bottom of my cherished Scanpan frypan , then I cut a ring to suit the outside dimensions of the bottom of my Scanpan saucepan . I glued this ring onto the big round bit .
Now the saucepan sits in the saucepan without moving and there is no damage , even on the worst corrugations .
Sound like a pathetic idea I guess , but I was pretty chuffed at the end result .
Willie .
AnswerID: 319301
Reply By: DIO - Wednesday, Aug 06, 2008 at 09:01
Regarding breakables, make sure that you buy only cheap stuff as that way in the event of breakage the $$$ loss is reduced. That's of course if saving money is important to you. I use large plastic boxes that fit into my cupboards. Make sure that glass items are not side by side, separate with packets or boxes of food etc. Really comes down to a bit of common sense consistent with your standards.
AnswerID: 319310
Follow Up By: Member - Graham H (QLD) - Wednesday, Aug 06, 2008 at 13:15
For glasses and mugs buy some foam about 50-60mm thick and using the item for a pattern cut holes in it and fit them in that.
Firstly though cut the whole sheet to the cupboard size then work out how many glasses etc you can get in without them touching.
You can buy a whole 4 person dinner set in lightweight material from CAMEC for about $40. DONT BUY THE REAL CHEAP ONES as they wear quickly and taste drinks.
FollowupID: 585923
