BASIC LPG setup guide...
Submitted: Wednesday, Aug 06, 2008 at 15:48
ThreadID: 60536 Views:8839 Replies:5 FollowUps:3
Hi all, first post, so please be gentile.
I has a 1991 Nissan Patrol, with an IMPCO 300A LPG setup on her.
I am after a guide on how to setup the 'impco' system as at the moment she couldn't pull the top of a custard going up hill.
On petrol (unleaded) it runs fine, so i am assuming its a setup issue with the impco.
Does any one have a guide on how to set up/tune up these systems?
Thank's in advance.
Chris.
Reply By: Member - Olcoolone (S.A) - Wednesday, Aug 06, 2008 at 15:52
The first thing I would check is the converter, make sure it is not blocked (water inlet / outlet) or freezing up.
AnswerID: 319377
Follow Up By: chriswoo - Wednesday, Aug 06, 2008 at 16:04
Is that as simple as removing hoses and flushing??
FollowupID: 585958
Follow Up By: KennyBWilson - Wednesday, Aug 06, 2008 at 16:12
take it to a gas fitter/installer, more than likely it needs a tuneup on the gas side.
FollowupID: 585961
Follow Up By: DIO - Wednesday, Aug 06, 2008 at 18:20
Too dangerous to mess with. Take it to an authorised service centre.
FollowupID: 585981
Reply By: Brew69(SA) - Wednesday, Aug 06, 2008 at 19:54
OT a bit but here goes. A gas tune should only cost $60 in any case.
Some useful advice for TB42 owners on lpg......................................
1) Fit high quality spiral core leads 8mm minimum.
2) If you have a points distributor put a ignitor electronic ignition conversion in.
3) Use good plugs.
4) ensure you have a good coil,
5) If it's an auto and you tow then invest in a manual torque converter lock/unlock set up.
6) Keep your cooling system in tip top order.
Never rely on a non lpg mechanic to tune your vehicle.
AnswerID: 319426
Reply By: chriswoo - Wednesday, Aug 06, 2008 at 21:00
Could anyone recommend a LPG fitter In hobart?
AnswerID: 319452
Reply By: Member - kevin Y (SA) - Wednesday, Aug 06, 2008 at 22:07
yellow pages ------never repeat never play with system yourself
AnswerID: 319472
Reply By: Member - MUZBRY (VIC) - Monday, Aug 11, 2008 at 07:44
Gday Chris
Ring me on 03 9580 4853 for a two minute chat about your car
Murray
AnswerID: 320201
