2.8 Nissan Patrol "99"
Submitted: Wednesday, Aug 06, 2008 at 16:42
bevan83
I am looking at buying a 2.8 but have heard the engine blows up, or it was the 3.0 im not sure. could anyone tell me anything they know about this model good or bad, and what kind of economey it might have. im am going to do the cape in it next year if i buy it. it has 195,000km on it and has a service history with nissan. and should i put an extra
fuel fillter it it to keep contamnation out of the
fuel ? all info would be great
Thanks Bevan
Reply By: On Patrol (Project TONI) - Wednesday, Aug 06, 2008 at 16:47
bevan83
This subject has been done to death mate, a simple topic search on this site will give you a gold
mine of knowledge.
Colin.
319385
Reply By: Member - Troll 81 (QLD) - Wednesday, Aug 06, 2008 at 16:51
In my opinion get something with a bit more grunt. The engine problem was with the 3 liters up to 2003 I think....but not 100% sure. Do a search in here and you will find thousands of threads on the blown engines
319387
Reply By: Stephen M (NSW) - Wednesday, Aug 06, 2008 at 16:54
Sounds like a wind up ?? but anyway the 2.8 's are fine. If
well serviced it will look after you. There was a few with people talking about blown heads but as a member on here has one and was told the same thing after he spent a fair bit of time trying to find the heating issue turned out to be the header
tank. Had it fixed no issues. The box isn't as strong as the 4.2L diesel but is fine behind the 2.8. Expect in the 10/11L per 100 free way. You might need to look at upgrading the
suspension if going to the top. If it still has the same
suspension (original) I would say it would be r/s and will fail as soon as you hit the rutted roads. If your looking for info in regards to the 3 litre do a search on here. Not going down that path.
319388
Reply By: stefan P (Penrith NSW) - Wednesday, Aug 06, 2008 at 17:41
Yep what they all said.........Happy 98 2.8 owner :) Now 175 000kms
I have typed all about the 2.8 several times a search will find them
319398
Reply By: Gunna Do - Wednesday, Aug 06, 2008 at 17:58
bevan83,
Have a 98 2.8 ltr G.U. Patrol with about 138,000 ks on it. No major problems to date. Just remember that this motor is no rocket engine and takes a little to get wound up. Fitted with a power up chip and it turns into something quite good but still no sports car.
Only extra filter fitted to
mine was an adaptor plate to replace the original
fuel filter with a C.A.V. type filter.
Have heard rumours about this motor blowing turbos but have not known any myself. Try the patrolforum as this will usually have all the possible problems.
My
fuel consumption is 14-15 ltr/100kms, never got below 14 but often higher.
If you are a patient driver this vehicle will serve you
Regards Gunna Do
319402
Follow Up By: bevan83 - Wednesday, Aug 06, 2008 at 19:28
Gunna Do,
thanks mate was wondering about a cip, power dose not bother me i drive a 82 desiel duel cab hilux and going over 100 is an effort. i read that they can be hard to start, what do people mean buy that, would'nt changing the glow pulgs fix that ?
Cheers Bevan
585997
Follow Up By: Gunna Do - Thursday, Aug 07, 2008 at 15:47
Bevan83,
I have never had any problems starting my patrol, the chip gave a good increase in power and reduced the turbo lag in the lower rev range, and I am not sure about what it did to the
fuel consumption at the time I thought it did not alter it too much. Price for the chip was about $1200.00 but money
well spent I think.
Regards Gunna Do
586204
Reply By: sweetwill - Wednesday, Aug 06, 2008 at 20:07
bevan 83
having owned a 99 2.8 i was more than satisfied with its performance. never had a problem starting it,yes it was a little under powered especialy if towing a 5 meter boat up a
hill,as for
fuel ecomomy it was around 13 to 14 liters 100 ks more if towing the boat. the comfort was like driving my car. if i was going back to 4x4 in all honesty i think the 4.2 would be a better option
bill
319433
Reply By: Best Off Road - Wednesday, Aug 06, 2008 at 20:22
You would do a lot better with a 4.5 Petrol on LPG.
Heaps more grunt and cheaper to run.
Disclaimer: LPG may be expensive and/or have limited supply in remote areas.
Jim.
319440
Follow Up By: bevan83 - Thursday, Aug 07, 2008 at 09:32
im on a budget, and this car is top knoch, will up grade later down the track. plus you cant beat a desiel is the bush
586129
Follow Up By: Best Off Road - Thursday, Aug 07, 2008 at 09:55
"You can't beat a diesel in the bush"????
This is a misnomer.
The 4.5 has more power, more torque and with the combined
fuel capacity of LPG and ULP, better range. Hence a better bush vehicle.
Also a better road car. Also more economical to run. Also a better tow vehicle.
Shouldn't be any dearer to buy, quite possibly cheaper.
Anyway, your money to spend anyway you wish. Just throwing up some thoughts.
Jim.
586136
