howling moon
Submitted: Wednesday, Aug 06, 2008 at 20:52
socket
g,day, we have a problem with our howling moon roftop tent. every morning when we pack up to move on the underside of the matress is damp from the previose nights sleep . i was wondering if anyone else had has this problem & any ideas how to rectify/. it is mounted on a full length arb rack , any info or ideas would be appreciated. thanks dave
Reply By: Vivid Adventures - Wednesday, Aug 06, 2008 at 20:58
It is not the sleep that does it... it is the condensation of the moisture in your breath, principally, but also perhaps from the damp tent or damp clothes.
You could avoid
camping when it will be colder outside than inside.
You could avoid breathing in the tent.
You could have more ventilation and accept that it won't be as cosy (get warmer sleeping bags). Oh, and avoid getting it wet (some sort of fly), and avoid taking wet clothes into it.
319451
Follow Up By: socket - Wednesday, Aug 06, 2008 at 21:46
you could avoid wasteing electricity by not sending the bleeding obviouse on your computer , dave
586045
Follow Up By: Vivid Adventures - Wednesday, Aug 06, 2008 at 22:35
Start taking your pills socket. If it's obvious (there is a spelling checker here) why ask at all?
I made constructive suggestions, but I was taking a humorous angle on how damned hard to stop condensation it is, entirely esp on cold and windy nights..
As
well as what runs down into the base, you're probably getting the condensation from the proximity to the cold metal of the roof rack. Try some insulation either under the tent or under the mattress - you can get polystyrene with a coating on it... you could try that too.
586065
Follow Up By: troopyman - Thursday, Aug 07, 2008 at 05:28
Hahahahahaha
586095
Reply By: Cape York Connections - Wednesday, Aug 06, 2008 at 21:11
You say the under side of the matteress.
Is that the bit on the roof rack side or have I read it wrong.
All the best
Eric
319454
Follow Up By: socket - Wednesday, Aug 06, 2008 at 21:52
g,day eric , yes it is the underside, the roofrack side. i understand how it happens ,with warmth inside & the cold air outside between roof & tent base, but it is a pain to remove mattress to dry every day , hope you have an idea , thanks dave.
586050
Follow Up By: Cape York Connections - Wednesday, Aug 06, 2008 at 21:56
I think you will find its body perspiration from you and partner going through the foam mattress. If its a cotton covered foam.
Just A thought.
All the best
Eric
586052
Follow Up By: socket - Thursday, Aug 07, 2008 at 20:05
yep you could be right eric , i am going to try an underlay suggested by another reply , see if it works thanks dave
586245
Reply By: Shaker - Wednesday, Aug 06, 2008 at 21:55
There is an underlay available that will stop this, used on boats a lot.
You will have to Google it though, I can't remember the name of it.
319468
Follow Up By: Shaker - Wednesday, Aug 06, 2008 at 23:01
Found it ..... Have a
LOOK HERE!
586070
Follow Up By: socket - Thursday, Aug 07, 2008 at 20:11
thanks for reply ,i found a few sites selling underlays for exact problem we have. dave
586247
Reply By: neil&brenda - Wednesday, Aug 06, 2008 at 22:13
Used to suffer from the exact problem you are having. A plastic sheet/ cover solved it (on the bottom of the mattress) . Had a mattress with a vinyl bum. Worked
319477
Reply By: Ted (Cairns) - Thursday, Aug 07, 2008 at 09:39
I have noticed the same problem. One way to deal with it would be this:
lattenrost Highly recommended for the home bed too. The idea is to provide maximum ventilation under (i.e. horizontal) and through (i.e. vertical) the mattress
319532
Reply By: TD100 - Thursday, Aug 07, 2008 at 21:43
socket,
is it an eezy awn or a deluxe style as i have the later with the 65mm high density mattress and in 4 years and 3 bods in it i have never struck that,wet walls and roof yes but not the mattress. strange indeed. cheers Paul
319658
