Pathfinder Towing questions
Submitted: Thursday, Aug 07, 2008 at 06:15
Member - Carolyn M (QLD)
Have been wondering about this for sometime, finally asking - when towing my van, is it best to have the overdrive on or off? I found out recently that
fuel consumption improves with it off under 80-90 and wondered if that was the same when towing.
Also, what is the best method for towing up ranges - ie the
Toowoomba range. Should I 'go for it' or ease it up. Only towed up the range once and foolishly got stuck behind a big bus, sucking in all his hot air, and car overheated so pulled over, made a cuppa and took off when all was good again. Have since been told not to sit in behind big rigs when going up ranges.
These may seem silly questions to some, but I have always thought that the only silly question is the one you don't ask.
10 sleeps until I set off to Uluru, SA, outback NSW on way home.
All and any suggestions greatly appreciated.
Happy Travels,
Carolyn
Reply By: Stephen M (NSW) - Thursday, Aug 07, 2008 at 06:30
Personally I think alot depends on the vehicle. Some transmissions are more responsive then others, meaning some will kick back out of o/d quit easily and others if for memory like the pathfinders (not sure what model you are talking about) but the older shape with the 3.3 V6 seem to really hang on in o/d and some times required a quick jab of the throttle to get it to kick back even though you could feel them labouring. Where as say a commodore you will kick back out of o/d with the slightest touch of required power. To me when it hangs on this is what is doing damage to the auto box as its labouring making those clutch packs in the box heat up trying to hang on in o/d. I think the easiest way to tell is if you can keep your foot in one spot on the throttle and dont notice any speed decrese then its fine. If you find the speed decreaseing but the box is not kicking back then you should be out of o/d. When I use to tow the van up hills in an auto depending on the steepness of it I would lock it back in second (auto) to stop it hunting between 2nd and 3rd and never sit up the rear of anyone because if they are towing as
well they are working their vehicles just as hard and you are copping all the heat coming from there vehicle. The better the air flow to the front of your vehicle the better. Just my opinion on the above, that what I have found myself. Regards Steve M
319505
Follow Up By: Member - Mark G (NSW) - Thursday, Aug 07, 2008 at 10:26
yeah good info STEPHEN, a steady approach will be helpful on the drive line.
a good rule of thumb is avoid changing gears going uphill if you can.
586143
Reply By: deserter - Thursday, Aug 07, 2008 at 12:41
I leave the Prado in auto and let it decide. Must say though it kicks back to 4th a hell of a lot. Takes a fairly flat road and no headwind for it to kick into o'drive.
What weight are you towing ? I kept the speed up pretty good going up to
Toowoomba. No probs. Thats towing just under 2000KG.
319555
Follow Up By: Member - Carolyn M (QLD) - Thursday, Aug 07, 2008 at 15:39
Many thanks everyone,
Towing about the same weight as you deserter; my problem with the Toowomba range I think was my own fault, stayed in behind the bus when I should have dropped back - first time towing up mountain and really had no idea, older and a little wiser now.
Carolyn
586202
