lift kit landcruiser ute
Submitted: Thursday, Aug 07, 2008 at 21:11
qubert
does anyone know what is the maximum lift kit i can put in a 79 series ute without having to alter the steering system. thanks
Reply By: nsngood - Thursday, Aug 07, 2008 at 21:18
G,Day qubert,
I presume the 79 series has leaf springs ??
319648
Follow Up By: qubert - Thursday, Aug 07, 2008 at 21:20
coil front.
586263
Reply By: nsngood - Thursday, Aug 07, 2008 at 21:40
Qubert ,I am not familiar with the cruisers but i assume the have a panhard rod which will be your first concern when lifting any coil spring (unless of course they have independent front end ???).
If so when you lift the
suspension you will move the diff sideways which will result in crabbing and some degree of unstability.
This being said you will not be able to lift much at all unless you start modifying bits and pieces.
Adjustable panhard rods are availaible and any lift over about an inch and a half will require them.What state are you in as in wa a lift over two inches total (body tyres or
suspension in a combination) is subject to engineering approval and a lane change test.Costly yes, but so is having your insurance voided.
319656
Reply By: Member - Ruth D (QLD) - Friday, Aug 08, 2008 at 16:20
We put one in our new 79 last year - don't know the specifications but contact Fred's 4WD Conversions (I think he may be an advertiser here) in
Toowoomba (he goes everywhere) and ask him. He's the expert. He did ours.
319795
Reply By: Member - Phil G (SA) - Friday, Aug 08, 2008 at 21:47
No mods required with 2" lift and 40mm longer travel shocks on the 79series.
As soon as you go higher, you will need to extend the brake lines, use a caster kit etc
319856
