Fixing High Density Poly?
Submitted: Friday, Aug 08, 2008 at 09:25
Richard_
50 liter
water tank turned up yesterday along with a free crack!
Any suggestions as to repair or does it go to
the tip?
TIA
Richard
Reply By: Member - Olcoolone (S.A) - Friday, Aug 08, 2008 at 09:42
Are you sure it is HDPE, the only way of repairing HDPE properly is by welding.
You could try superglue or MEK Solvent (Methyl Ethyl Ketone) but doubt the long term ability.
319720
Follow Up By: Richard_ - Friday, Aug 08, 2008 at 09:51
Yep, sure is, see
here
Richard
586333
Reply By: Member No 1- Friday, Aug 08, 2008 at 09:43
plastic welding?
need special heat gun, but you should be able to find someone... Rasch Plastics might be a good start
319721
Reply By: Matt(WA) - Friday, Aug 08, 2008 at 09:59
Richard,
Is it a new
tank? If it was I would be asking for a refung. If not plastic welding is the go. Talk to a few local panel shops or any motor bike repair shops(plastic weld farings).
Hope this helps.
Matt
319724
Reply By: Richard_ - Friday, Aug 08, 2008 at 10:23
Thanks everyone for your quick replies.
Bad news is that seeing I'm in
Nhulunbuy NT, return to Queanbeyan NSW is probaly going to cost me more than what the tanks worth!
Good news though, just spoke to a Plastic Welding company in
Darwin here, they have one of their blokes coming over in a months time to do some plastic pipe welding for the mining company.
Damn it's good to have a win every now and then. :-]
Richard
319729
Follow Up By: Gramps (NSW) - Friday, Aug 08, 2008 at 16:21
LOL you'd better get some extra lottery tickets :)))
586403
Reply By: Cruiserman1961 (QLD) - Friday, Aug 08, 2008 at 19:27
Howdy Richard,
i very much doubt that the
tank will be high density polyethylene. It's most likely low to medium density as high density is very hard to mould. Those tanks are manufactured using a method called rotational moulding. A steel mould is filled with ground Polyethylene and then rotated in an oven on both axles. I have been making poly tanks for 6 years. Only way to fix it is to weld it with suitable welding rod and either a hot air gun or a welder called a "Drader" which works a bit like a soldering iron and injects molten plastic into the weld. No glue will ever stick to the stuff i am afraid.
Cheers, Udo
319829
