points gap
Submitted: Friday, Aug 08, 2008 at 10:02
ThreadID: 60602 Views:9168 Replies:8 FollowUps:2
Hi all,
Wondering if anybody could tell me the points gap for a 2F toyo donk please?(denso dissy).dwell angle would be nice too if possible!
Wazza
Reply By: Member - Phil G (SA) - Friday, Aug 08, 2008 at 10:26
My recollection is 18 thou (range 16-20 thou). I didn't use metric back then.
But can look up tonight if you don't have an answer by then.
AnswerID: 319730
Reply By: Member - William B (The Shire) - Friday, Aug 08, 2008 at 11:00
Hi Wazza,
from memory dwell should be around 52 degrees.
William
AnswerID: 319736
Follow Up By: Member - Phil G (SA) - Friday, Aug 08, 2008 at 20:11
Gee William, you might have got it mixed with the other Toyotas. My old Gregorys say 41 degrees for the 2F.
FollowupID: 586441
Reply By: Member - Olcoolone (S.A) - Friday, Aug 08, 2008 at 12:19
Buy a workshop manual.
AnswerID: 319756
Reply By: wazza71 - Friday, Aug 08, 2008 at 13:01
40 odd bucks for a manual,olcoolone,or ask people on a FORUM who may know off the top of their head.hmmm.
for the record...Im a mechanic,at work on an oil rig for 3 weeks.so just thought i'd try to get an answer before i get home.
have squeezed 290 km out of atank of gas around town but lately its dropped off a bit.set the new points by eye.maybe its tappets time again!
cheers to others helpful answers.
wazza
AnswerID: 319764
Reply By: Member - Graham H (QLD) - Friday, Aug 08, 2008 at 14:42
Google is also your friend In 2 mins found this Maybe helpful and cheaper than a manual
http://www.toyotafjcruiserforums.com/old-school-fj-40/91-fj-40-2-f-engine-timing.html
AnswerID: 319779
Follow Up By: Member - Phil G (SA) - Friday, Aug 08, 2008 at 15:26
Hehehe
Graham, thats the timing, not the points gap :-)))
FollowupID: 586391
Reply By: Member - Graham H (QLD) - Friday, Aug 08, 2008 at 16:53
Oh well he can do that as well now and try this instead
http://www.jtoutfitters.com/spark-plugs-toyota-land-cruiser-fj40-fj60-p-9988.html
AnswerID: 319807
Reply By: Member - Phil G (SA) - Friday, Aug 08, 2008 at 20:20
Wazza,
Got all the numbers in front of me now (Gregorys #511 manual for the 2F):
Firing Order 1-5-3-6-2-4
Spark Plug Gap 0.8mm (Conventional Ign) 1.0mm (Semitransistorised)
Contact Breaker Gap 0.45mm
Dwell angle 41 degrees
Ignition timing 7 deg btdc
Idle speed 650rpm
Valve Clearance (hot) Inlet 0.20mm; Exhaust 0.35mm.
AnswerID: 319837
Reply By: wazza71 - Saturday, Aug 09, 2008 at 10:59
thankyou phil,thats what i was after,cheers.was thinking after,that 50deg is not right for a 6.thats probably for the 4cyl bundera.
graeme ,thanks for your links.the second one just covered the plug gaps and firing order.cheers all the same!
'avagoodweekend.
AnswerID: 319926
