Diesel Cost
Submitted: Friday, Aug 08, 2008 at 13:06
ThreadID: 60607 Views:2513 Replies:9 FollowUps:8
$168.9 Port Road West Hindmarsh
Reply By: Mr Pointyhead - Friday, Aug 08, 2008 at 13:23
Wow, that is cheap :(
AnswerID: 319769
Reply By: Member - Andrew (QLD) - Friday, Aug 08, 2008 at 13:43
Is that per litre or for your whole tank? {shock}
Andrew
AnswerID: 319773
Reply By: Member - kevin Y (SA) - Friday, Aug 08, 2008 at 14:39
varies between smithfield $!.76gawler $1.73 parafield $1.75 litre
AnswerID: 319778
Follow Up By: Willem - Friday, Aug 08, 2008 at 14:55
And a $1.75 here, 250km north of Adelaide. You are being dudded!
FollowupID: 586380
Reply By: madcow - Friday, Aug 08, 2008 at 14:46
$1.75 here in wodonga
AnswerID: 319781
Follow Up By: Leroy - Friday, Aug 08, 2008 at 14:55
Ours only dropped earlier in the week from 190.9 to 185.9! It was 197.9 last week and it's a good idea to use it with the cool weather about :)
Leroy
FollowupID: 586379
Reply By: Louie the fly (SA) - Friday, Aug 08, 2008 at 17:31
$1.75 in Woodside. Still being shafted! ULP still $1.46
AnswerID: 319809
Reply By: deserter - Friday, Aug 08, 2008 at 17:36
$1.64 on the Sunny Coast - after the 4c discount.
AnswerID: 319811
Reply By: Off-track - Friday, Aug 08, 2008 at 19:15
1.59 in Townsville non-discount Caltex
AnswerID: 319825
Reply By: Ozboc - Friday, Aug 08, 2008 at 21:07
home brewed .. 0.05cpl
AnswerID: 319849
Follow Up By: Waynepd (NSW) - Friday, Aug 08, 2008 at 21:55
wish i game enough to do that boc
FollowupID: 586469
Follow Up By: Gary n Kerry - Saturday, Aug 09, 2008 at 10:22
you have got me curious. how do you brew?
FollowupID: 586522
Follow Up By: Ozboc - Saturday, Aug 09, 2008 at 11:58
Gary - follow this link
http://www.biodieselcommunity.org/gettingstarted/
FollowupID: 586548
Follow Up By: Austravel - Saturday, Aug 09, 2008 at 20:59
What vehicle are you running the bio in, if you don't mind me asking?
Also wondering how you ensure consistency. Am doing bio diesel tests currently on commercial bio diesel and know I wouldn't run it through my vehicle. That is at 100% which is the only way you can quote your cost figures. Ie by going B20, B50 etc it'll increase the overall costs. Even commercial bio appears to be all over the place when analysed. Maybe ok if the engine is old style technology I wouldn't run it in newer vehicles. Fuel pump repairers have told me it's been a boom for their business, repairing pumps and injectors from running high % bio.
Any feedback would be great.
FollowupID: 586655
Follow Up By: Waynepd (NSW) - Saturday, Aug 09, 2008 at 21:56
Ozboc,
Fascinating read. When i retire in a few years time to my farm i can see a bio diesel plant in my future.
On Tillys forum
Who is neutral? Good to see an Aussie sharing info with the world.
As with all forums there are varying opinions about methods and results gained by individuals' experiences....
FollowupID: 586689
Follow Up By: Ozboc - Sunday, Aug 10, 2008 at 09:44
HI , i run it in my nissan Patrol 4.2TDI 2000 model -- been running it for 2 years now - No ill effects , if anything it quietens the motor down and i dont have any smoke when i nail it. i run at anything from 100% to 10 % - depending on how much i have -- the time of year ( ie i used different feed stocks )
oil stays cleaner for longer ( less ash deposits ) fuel injectors are cleaned as its running through it
as for checking it - diesel motors are not high performance motors like you would find in a F1 car and therefore does not require an extremely refined / complicated fuel ( with exception of the newer diesels ) considering some people even run there diesels on SVO ( straight vegi oil) this is a testament to the diesel motors reliability , after all Rudolf diesel made these motors to run on very primitive oils such as coconut oil and such
I check my batch in a very simple way .. The Jan Warnqvist's Conversion Test
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/9411061471/m/8281092351
This is biodiesel , not rocket science - this works great in my 4x4 and i have had no issues with my 4x4 in 2 years , have not even needed to have injectors cleaned or serviced in this time & i tow a 1300 kg Caravan - i would have saved well over $3000 in fuel last year
I have also spoken to people in the earth moving industry that have been running bio in there bob cats and other small plants for well over 5 years now without issues.
You here a lot of people winge , but i have never MET ANYONE personally that had an issue with bio , its always been - " a friend of mine knows a guy " situation
Yes there can be an issue if your running an older engine ( pre 1988) where rubber seals are used in the motors/ pumps rather than viton seals - this will present an issue for those owners and people think that the caustic you use in the conversion process destroys your engine , this could be the case BUT you actually "wash your diesel several times untill the water is clear - this removes the caustic and methanol from your batch after the conversion has taken place.
when washed correctly the diesel will actually be cleaner that the crap you buy at the petrol station - you can test this for yourself -- get a small amount of diesel in a jar -- add water - shake - you will get a white emulsion separate from the diesel , this is the detergents , alcohols and other impurities in the diesel - with home made Bio - its washed till the water is clear - then dried
i could go on for hours , but im a little to hung over today :) either way -- i have now left 2 very useful links - the one on this post also goes to a forum that has a great bunch of people on there who are very willing to help with any problems ......
Boc
FollowupID: 586737
Reply By: Waynepd (NSW) - Friday, Aug 08, 2008 at 21:45
We have 174.9 and 176.9 for diesel at Heathcote NSW
Don't know about ULP
AnswerID: 319855
