Diff breathers for the D22 Navara
Submitted: Friday, Aug 08, 2008 at 13:36
ThreadID: 60608 Views:5515 Replies:3 FollowUps:4
Looks like I have this weekend off. First since I got back from the EO grathering.
Looking at fitting breathers to the diffs & transfer cases. Has anyone carried out this work. Things to look out for, Any special bits I will need ?
Vince
Reply By: Ross H (QLD) - Friday, Aug 08, 2008 at 15:17
Hi vince
I think you will find the d22 has high breather on every thing except the rear diff. All the others either go to the air box or high on the fire wall in the engine bay. In saying that when I did the cape trip a few years ago with a lot of deep water crossings I checked the rear diff when I got back and all was fine. But I guess if you get stuck thats a different story.
Regards ross
AnswerID: 319787
Follow Up By: Vince NSW - Friday, Aug 08, 2008 at 15:49
Thanks Ross. Must admit that I have not had a real good look around the front, but I did notice that there was no breather on the rear when I have been under there running wires for the camper trailer connection.
I will have a good look tonight if the snow holds off in the Blue mountains. Cold a a frogs 's last night when I was working in the ute back trying to fix the dust proofing. I will beat the dust.
Vince
FollowupID: 586398
Follow Up By: Member - Mark G (NSW) - Friday, Aug 08, 2008 at 16:52
gday guys
i have a 2004 model nav & i just looked on the rear diff & it has a breather that disapears up into the body some where. where it goes from there i will have to investigate further.
FollowupID: 586405
Follow Up By: Ross H (QLD) - Friday, Aug 08, 2008 at 19:22
Mine has a breather on the rear diff and it goes up to the bottom of the tub. I have been through water up to the windscreen and haven't had a problem. Maybe it is just good luck but it seems to work or you might just get an air pocket under there don't really no. But as I said in my first post I do check my rear diff for water regularly.
Regards Ross
FollowupID: 586428
Reply By: Member - Bucky (VIC) - Saturday, Aug 09, 2008 at 03:43
Vince
Diff breathers are already there.
Or at least on my old 2003, D22 they were !
You will find that that they come up in the engine bay, close to the top of the firewall, at either side, and hook back over, and stop ..
They are very distinctive
Bucky
AnswerID: 319881
Follow Up By: Member - Mark G (NSW) - Saturday, Aug 09, 2008 at 08:01
hi bucky
there're the ones that look like brake lines that dont go anywhere arn't they?,next to the fire wall?
FollowupID: 586490
Reply By: Member - Bucky (VIC) - Sunday, Aug 10, 2008 at 08:48
Vince
I recon you are right, they just hook over, and stop.
Maybe best to use a length of clear fuel line, if you have any, or a garden hose reduced down at one end.
Caution there !....do not use compressed air, a good strong breath is all you need
Which one goes where, I do not know. I suspect that you would have to remove the breather pipe ( open the clip and slide off ) from each diff, ect and blow air thru them, get back under the bonnet, and listen for the hiss, whilst blowing.
Bucky
AnswerID: 320076
