HF Radio and Help for Hard-of-hearing
Submitted: Friday, Aug 08, 2008 at 19:35
Member - Sam S (NSW)
Hi all. I have tried to do some research on the net to find out what sort of
HF radio equipment is suitable for hard-of-hearing people. As an example I have read that it may be possible to get bluetooth-enabled software-defined radio but I would prefer something a bit more 'mainstream'. Are there any users out there with hearing aids I would be grateful if they could share their thoughts on
HF radio setups and what sorts of things can be done to improve the sound quality. In the same vein, is it possible to get any HF radios that allow the sending and receiving of text messages?
Reply By: SteveL - Friday, Aug 08, 2008 at 21:01
The Codan NGT is capable of sending text messages, but you will need to join a network that allows sending data instead of just voice and selcall.There is such a network starting up at the moment, it is called HFOZ. -Steve
319847
Reply By: Dennis Ellery - Friday, Aug 08, 2008 at 22:01
Mike there are two solutions I know of
The cheap one - I’ve tried and it is effective
Buy a good set of hearing protectors with a built in FM radio (Peltor will set you back about $150) The cheap ones you can buy for about $30 won’t do the job (I’ve tried them)
Next go to an electronics
shop such as Dick Smith or Strathfield and buy a FM radio transmitter for about $30 – this comes complete with a headphone plug that plugs into the headset or auxillary outlet on the radio. If your radio doesn’t have one it is only a minor job for a radio tech to fit one.
Of course if you don’t mind being hardwired to the radio buy a good headset and connect that to the radio
The expensive one – untried but possibly the most effective.
I have a set of hearing aids that cost me around $3000.
An accessory, a miniature FM radio module, or a radio loop can be purchased for these but you will have to talk to your audiologist about cost and technical requirements.
319859
Reply By: Member - Stephen L (SA) - Saturday, Aug 09, 2008 at 08:05
Hi Sam
As to your last request of sending and receiving text messages.
In you are a member of a recognized
HF Radio Club like the VKS 737 Radio Network, as far as I am led to believe, the allocated frequencies are for voice contact only and any form of data transmission is not permitted under the licences that are issued per the Australian Communications Authority.
I may be wrong, but give them a phone call to get it straight from the horses mouth.
319890
Reply By: Member - Phil G (SA) - Saturday, Aug 09, 2008 at 21:53
Are you interested in HF Email?
I haven't used it, but Reids radiodata are offering it.
Link here.
I've used their
Bushtelephone service for 5 years, and found it to be great for phoning home through the radio. If HFemail is of any use, then might be worth contacting Wayne
Reid and asking about it.
320042
Reply By: Bob Y. - Qld - Sunday, Aug 10, 2008 at 09:00
Sam,
Haven't used HF since about 1996 ,when we installed a couple of UHF repeaters. Prior to that we lived with them vitrually day & night.
I'd suggest a good quality set of head phones, fitted to a outlet on the HF, as Dennis suggested. Otherwise, fitting a larger, good quality speaker, reasonably close to where you use the HF might be a good alternative.
One of the problems with HF is the other "noises" that are present, during Rx, that can muffle, or override the voice.
We used to repeat many key words, or even whole phrases, as
well often spelling phonetically. I find UHF much easier to use, though many people mumble, or talk incoherently, if they are nervous.
Hooroo,
Bob.
320078
Reply By: Member - Sam S (NSW) - Sunday, Aug 10, 2008 at 10:23
Thanks all for your responses. I think the texting service plus some sort of wireless connection from a headphone jack on the hf receiver to the hearing aids sounds promising. I'll follow up those suggestions. Thanks again.
320091
Follow Up By: Member - Serg (VIC) - Sunday, Aug 10, 2008 at 11:15
Dennis’s suggestions most comprehensive. Good quality phones would be my first choice. Do not expect leap in improvements, however.
HF radio nature to be noisy. There are newer models on the market that have DSP (digital signal processing) that offer some improvement. But it still going to be noisy. Perhaps satphone will be better option? I personally went to
HF radio path and do not regret it. From my perspective it is great fun to use it and harder to understand making even more fun. Although understandable for some people it will be more frustration then fun.
Serg
586756
