OT Going Green-ish...the tanks are full
Submitted: Sunday, Aug 10, 2008 at 09:10
ThreadID: 60662 Views:3649 Replies:7 FollowUps:22
G'day
In 2006 we replaced our ageing electric hot water with a Solar heated system and it has worked well since and has haved arounf $200 per year in electricity costs.
At the end of 2007 we bit the bullet and replaced two galvanised Rainwater tanks and bought an additional one. I went and collected the tanks one by one from the neighbouring town where they were manufactured and that was an experience in itself.Then the two of us, with the help of some youngsters, shifted the whole lot into place...over two fences...more excitement :-)
This year however, our rainfall is considerably down from last year and I wondered if the tanks would ever fill. With the help of the continuous small doses of rain over the past week the tanks started overflowing yeterday.
We now have 19,000litres of collected water for drinking or for use on the garden. We had one tank plumbed into the house and upgraded the old toilet to a modern dual flush and were able to get some government rebates on these new installations.
The other thing we had done was to have a Power Audit done to the house and have replaced all the light globes with these new Superglow ones. It seems to have reduced the power bill a little bit.
Next on the list is to have house rewired and to have the 1930's powerbox at the front of the house replaced with a modern digital one. Some of the internal power supply still runs down along the inside of the walls without conduit...lol
Reply By: Member - Mark G (NSW) - Sunday, Aug 10, 2008 at 09:16
WILLEM
you are quite the GREENY IN TRAINING.
just watch you dont find youself chained to a bulldozer or perched on top of a tree in a forest somewhere. LOL :-)))
AnswerID: 320081
Follow Up By: Willem - Sunday, Aug 10, 2008 at 09:55
Hahahahaha
Somehow, I thinlk I am beyond that......lol
FollowupID: 586742
Reply By: Member - joc45 (WA) - Sunday, Aug 10, 2008 at 09:45
Hi Willem,
Good on you!
You must have plenty of space to fit all this stuff.
I've been thinking along the same lines, but I'm lacking space in my yard for the tanks, unless I hide them right down the back corner and pump water back. But I'd need a crane to get the tanks over the house down to the back.
Would like to dump my grey water out on the garden, but again would have to pump it up.
My roof runs east and west with only a 10deg pitch, so I'm stonkered for a simple installation of both solar water and solar electricity panels. I could put ugly angled frames on the roof running at right angles to the roof line, but that has its issues as well.
I might work it out. But I'm definitely not moving!
I guess I need another trip to mull it over.....
cheers, Gerry
AnswerID: 320083
Follow Up By: Willem - Sunday, Aug 10, 2008 at 10:00
Gerry
Yes, we have Half an Acre of land in a country town with vehicle access via a wide rear laneway. House built of sandstone and is 108 years of age. Has high pitched roof running east/west like yours buit with northfacing side for continuous heat for solar panels. We also have multiple outbuildings for rainwater catchment.
FollowupID: 586746
Follow Up By: Member - Ian W (NSW) - Sunday, Aug 10, 2008 at 12:06
Gerry,
An alternative in your situation might be a "heat pump" water heating unit. In general terms its you refrigerator turned back to front. Those hot coils mounted on the back of your fridge for cooling are wrapped around the water tank, the 'cold panel" that normally chills down the freezer compartment is on top of the roof or in the case of current models are merely mounted above the water tank with a recirculating fan.
Very efficient, reduced my water heating costs by more than fifty per cent.
Ian
FollowupID: 586759
Follow Up By: Member No 1- Monday, Aug 11, 2008 at 08:31
Ian...wait till the compressor goes bang
heat pumps are cheaper to run but more ..much more expensive to fix if the heart of the system fails
FollowupID: 586878
Follow Up By: Saharaman (aka Geepeem) - Monday, Aug 11, 2008 at 10:22
Gerry,
I support what Ian W said in his reply.
After extensive research we decided on a Heat Pump system as we did not like the idea of putting a typical solar system on our roof (“ugly “.
We chose the Quantum system invented and manufactured in Newcastle.
Ours is a 360 litre one and with 4 adults (3 female and one male = about 6 people) it costs about 25 cents a day for hot water. It is incorrect to say the compressor will not last – they would have a similar life expectancy to a good quality household fridge compressor – about 20 to 25 years. In comparison we have friends whose normal solar panel system on their roof required repairs to the core unit – on a highset house they had to hire a crane to get it off, take to the workshop and then hire a crane to put back on roof again. A VERY expensive process.
As stated above heat pumps work as a reverse air conditioner – in this case cold air is a by product . You can duct this into your home if you want for free “air conditioning” and put a bypass in for winter months. The cold air by product is traditionally 10 degrees Celsius lower than the ambient temperature. They work in all weather sunny or not and are exported to Canada even.
Check out www.quantumenergy.com.au
I am not associated with Quantum – just believe they have the best product of this type. They were the first to make this technology available commercially for heating hot water.
As it is still solar (taking heat from the air) you still get all the relevant State and Commonwealth subsidies that exist.
Glen
FollowupID: 586908
Follow Up By: Member No 1- Monday, Aug 11, 2008 at 10:59
firstly and to make a point..i have not said the compressor wont last...its very more expensive to replace the heart of such systems than an electric element
the SA gov have banned (or about tol) replacement electric element type hotwater services...you can still get your heater fixed but it cannot be replaced with a new element type....not sure if its law right now and if not it will apply soon.....
The units that Quantum are quoting are only capable of cooling a small room..if that......
and what is going to cool your house (err bathroom as thats how big a room it can do) when the hot water storage tank thermostat tells the heatpump it does not need to heat the water anymore?...it will not work....
FollowupID: 586918
Follow Up By: Saharaman (aka Geepeem) - Monday, Aug 11, 2008 at 11:25
The cooling aspect is a "FREE" by product - so its not an issue how much it will or will not do. This is not the reason you buy one. But if its ducted into the house for summer whatever hours its "on" it helps with your core means of cooling - air conditioning or whatever. With the solar panel type - there is no free by product at all and they only work when its sunny. My point is that heat pump type systems are better (in my opinion) than the solar panel systems as they (1) don't have to be on your roof to look unsightly; (2) they work 24 hrs a day in any weather; (3) cost a minimal amount to operate (about the same as a fridge for 3 or 4 hors a day); and (4) you get free cold air as a by product if you can utilise it (for 3 or 4 hrs per day).
I think you are right about electric element ones - they are about to be (or soon will be banned) in all States for new installations. Its true that a compressor would be far more expensive to replace than an element - but a plumber I spoke to recently said the new electric units only lasted a bout 7 or 8 years anyway and they cost a lot more to run with electricity. I think a compressor should last at least 20 years if its only used a few hours a day.
Its a personal choice but we chose the heat pump type for I believe valid reasons is all i'm saying.
FollowupID: 586924
Follow Up By: Member No 1- Monday, Aug 11, 2008 at 11:59
"I think a compressor should last at least 20 years if its only used a few hours a day."...yep have seen many last that log and just as many last less than a year...on average say 10-15......and not withstanding the fact that lots of other faults happen that could wipe out the compressor..eg refrigerant leak
gas is better way to go as the maintenance costs are much less but not everyone has access to NG..lpg is expensive
if i had my way an no access to gas i'd go solar....and i'm a fridgie
...might get a heatpump backup ....lol
at the high discharge superheat settings that those things are needed to operate it does put the system under somewhat of strain when its operating...if the water temp is controlled to 60C the discharge temp of the refrigeration system must be around 65-70 whereas as normal heatpump temp is around 50-60 when operating in heat mode....these are very high discharge temps (ie...to pump high discharge temps requires higher pumping (discharge) pressures) which has a direct bearing on compressor life...both mechanically and electrically
FollowupID: 586934
Follow Up By: Saharaman (aka Geepeem) - Monday, Aug 11, 2008 at 16:23
Are you referring to Quantum compressors that you say have lasted less than a year or refrigeration in general.
Quantum systems were originally built for the commercial market - Motels, hair Dressing Salons etc that had a high demand for hot water. I would have thought that the compressor would be built to the standard required such as high discharge pressures etc . Domestic use should see the systems used well below their capacity. But I acknowledge I am not an expert in this area as you are - all I have done is research on the various systems and talked to people who are using heat pumps.
PS heat Pump systems ARE considered to be SOLAR systems for compliance with the Government legislation for rebates.
FollowupID: 586986
Follow Up By: Member No 1- Monday, Aug 11, 2008 at 17:33
do quantum build their own compressors?...dont think so (but i stand to be corrected) as i reckon they would source from existing manufacturers...i refer to refrigeration in general
i would say that they use Standard off the shelf units ...ie techumseh, copeland, danfoss etc etc...a standard unit can easily pump those pressures...how ever, the main differnece being that heat pump aircon units dont run all day, every time upto or at those limits while the Hot Water systems would and do.... it is this increased workload that puts more stress on moving bits that will reduce longevity.....its a fact of life that more heat means more wear n tear
most reputable aircon units have 5 yr warranty on compressors...quantum have 2...they also only expect 12-15 yrs life cycle on the entire unit....so if its 12 it a bit short of your 20+yrs wouldnt you say......this is "considered" average life span of a heatpump aircon compressor...but will it actually go the distance under the increased working conditions on a HW service?...as i say above, increased heat = more wear n tear to moving parts
FollowupID: 586999
Follow Up By: Willem - Monday, Aug 11, 2008 at 17:45
Cheezes Member No 1
This is the most you have written in the last 5 years on the forum. Man, you are wealth of information....he he he
FollowupID: 587002
Follow Up By: Member No 1- Monday, Aug 11, 2008 at 21:02
you have just never read any of my posts, cos your never home...hahaha
FollowupID: 587075
Reply By: Tim Owen - Sunday, Aug 10, 2008 at 09:46
We put in an evacuated tube solar hot water service last week - after three cold but clearish days, the water (all 315ltr of it) is at a temp which is too hot to shower in. I've turned the instant gas booster off, and am feeling very good about not using any power for hot water (other than the little pump that circulates the water from tank to tubes). In the depths of Victoria - in the middle of winter. Fantastic. It is an expensive exercise, but the $3740 worth of rebates made it a lot easier. Good on you William - water tanks will be our next 'green' project (we've already changed our halogens to compact fluoros).
AnswerID: 320084
Follow Up By: Willem - Sunday, Aug 10, 2008 at 10:28
Tim
Some locals here have installed Solar Power as well whereby they can put electricity back into the grid. Minimum expenditure think think is $16,000 with an $8000 rebate from the Government.
FollowupID: 586751
Follow Up By: Member - Jack - Sunday, Aug 10, 2008 at 17:15
You have done well. I have a solar hot water system that is not worth two bob. I have to put a booster on every day to get water warm enough for a shower. Will probably call someone this week to get an off peak. Looked at heat pumps, but at $4k it's a bit beyond me.
Jack
FollowupID: 586808
Follow Up By: Willem - Sunday, Aug 10, 2008 at 17:30
Jack
I have Off Peak tarriff on a separate switch and have to use the booster in winter. Some mornings even the hot water pipes are frozen and one has to wait for the sun to warm them up. As soon as the weather warms up the J Tarriff stays switched off. Everything is a compromise. My Soloar water is an Edwards from WA.
FollowupID: 586809
Reply By: Member - Axle - Sunday, Aug 10, 2008 at 10:16
Hey Willem !!!, Ya can't go green around the house, then go into the scrub with a air polluting GQ nissan!. I can see a new common rail diesel 4by on the list now!.... Mr greenie,...hahahaha
Maybe a new D3 would do the trick!..LOL.
Cheers Axle..
AnswerID: 320089
Follow Up By: Willem - Sunday, Aug 10, 2008 at 10:25
Hahahahahaha Axle
D3 indeed......... OMDB
Thats why I said Green-ish...LOL
FollowupID: 586749
Reply By: Member - Mfewster(SA) - Sunday, Aug 10, 2008 at 14:24
W. Did you have any problems getting the rebate from the SA govt?
I put in tanks to run our toilets. Was told this needed either a 30 foot head to get enough pressure or had to have an electric pump. I modified the cistern so that it works with about 2 foot of head and no electric pump. Also used 6 industrial plastic barrels connected in series to give 1200 litres per toilet. Cost about $120. Works fine, even the half flush. They wont pay up.
AnswerID: 320118
Follow Up By: Willem - Sunday, Aug 10, 2008 at 16:58
Mfewster
Had no problems with the toilet rebate. In fact we boke even on that one. But with the tanks they stuffed us around a lot claiming computer troubles etc and in the end we only received $485 rebate instead of about $800. But at least it was something back and that paid for the plumber.
FollowupID: 586804
Follow Up By: Member - Mfewster(SA) - Sunday, Aug 10, 2008 at 17:36
W. I have also heard of others who have claimed the $800 and only received about $400 back(eventually) with no understanding of why they didn't get the amount advertised. The rebate system in SA seems very sus. The Minister late last year boasted that over a 1000 rebates has been given out. 1000!!!!!!! Given the water supply issues you would think the number would be MUCH higher than this unless there are issues with the rebate system. I'm also told that if you join a tank to your hot water service and also join to the toilets, they won't pay for both (but this doesn't show in the description of the scheme). My plumber reckons the rebate sytem is a joke and designed to look as though something is being done by the guvvament without actually doing anything at all.
FollowupID: 586810
Follow Up By: Member - Mfewster(SA) - Sunday, Aug 10, 2008 at 17:37
Meant to ask, did you have to put in an electric pump?
FollowupID: 586811
Follow Up By: Willem - Sunday, Aug 10, 2008 at 18:01
Yes, everything this government does seems sus. They even tried to take away our country hospitals. Now they have backpedalled for the time being but it remains to be seen how they will come back with a new stupid scheme. The Gepps Cross Line is alive and well...lol
I did not need to install an electric pump as the main tank is atop an old tank base and there is enough pressure to push through at least 6000 of the 6500litres.
I do have a Davey Pump for pumping between tanks or for whatever I need to do.
FollowupID: 586814
Reply By: Garbutt - Sunday, Aug 10, 2008 at 16:38
Good on ya Willem. We run our whole house (except dunnies) on our rainwater and rarely run out, and I think we get less rain than you. We also have a big shed to catch it and hold around 60,000 litres when full. All but full at present.
AnswerID: 320134
Follow Up By: Willem - Sunday, Aug 10, 2008 at 17:03
Garbutt
And there I was thinking I had reasonable storage...lol
A friend on the outskirts of Melbourne has a 150,000lt tank set between two large sheds.
Anyway, it all helps
FollowupID: 586805
Follow Up By: Member No 1- Monday, Aug 11, 2008 at 12:09
I'v thought about putting in 90000 lt underground cement but the cost says that even the new water pricing structure says its uneconomical.....when they get the desal plant up and running i want to know where they are going to the power to run it...bugga me looks like i'll have to turn the aircon off and put the tank in anyway & use it as a pool in to keep cool...
wish i new all of this was going to happen 8 yrs ago.... before we did renovations... too hard to put decent sized above ground tanks in now without them being unsightly......would have redesigned land and building layout if i'd known
FollowupID: 586935
Reply By: Member - Doug T NT - Monday, Aug 11, 2008 at 10:49
Willem
Going GREEN eh,, So was I at the wet season at El Arish, well not me so much as the Troopy and the Caravan , had to give them both a wash as they took on a greenish tinge from so much rain , the Troopy had green streaks running down from the roof line, not much rain where I'm at now though, just strong wind gusts and DUST at Tennant Creek,
AnswerID: 320225
