Assistance Needed in Broome
Submitted: Monday, Aug 11, 2008 at 16:21
WillyWish
Hello.
I've an employee towing a Kedron ATV Caravan from
Fitzroy Crossing to
Broome today. He's limping along after having had a side impact with a calf on the rear of the hilux resulting in a slight jackknife (this was on a gravel road at about 60kms/hr only) . The drawbar now has a small crack on one side about 50cm from the hitch and the other side appears slightly stressed or bent. On advice in Fitzroy from a engineer that it should be roadworthy, he decided to push on (at 60km/hr) to
broome (400kms) to get it assessed and maybe temporarily welded up. Anyway, I assume it is pretty hectic in
Broome at the moment but if anyone knows any engineering companies or fabricators that might be able to assist in
Broome then your advice would be much appreciated.
Thanks in advance.
Will.
Reply By: BT- Monday, Aug 11, 2008 at 19:15
Gidday Will,
I can give you a starting point. Give Minshull Repairs a ring on 0891921168. They are the local ARB and general motor repair mob in
Broome. They are very helpful and if they can't fix you up they'll point you in the right direction.
BT
320291
