Solenoid dual battery system
Submitted: Tuesday, Aug 12, 2008 at 14:37
ThreadID: 60717 Views:3069 Replies:2 FollowUps:5
I have the option to buy a solenoid governed dual battery system with the wires and a 10 month old battery to suit my vehicle for pretty much peanuts. As I'm on a budget, this option appeals but I was wondering about the pitfalls of this system.
As far as I understand it, this system is like having two batteries that are used virtually as one, so both charging and discharging together. Is this right? Does that mean the it's the extra capacity of having two batteries that gives me more charge over time? Also, will both batteries fully charge, even if they're different sizes?
Thanks.
Reply By: Affordable Batteries & Radiators - Tuesday, Aug 12, 2008 at 15:56
It would depend on how it is switched. The best is to switch it with the accessories position of the ignition so that it is off when the key is removed so your fridge etc can keep running off the aux and leave the main fully charged (this can be done by tapping into the wiper motor harness). You don't want the solenoid to stay engaged as it will keep the batteries linked and the fridge etc will drain both as well as the solenoid drawing the batteries down (Approx 0.3 to 0.6A /h). The advantage of the accessories position is that it is normally off during cranking so that the aux is not linked to the main during cranking.
I can email you a instruction sheet if you wish.
Most batteries will charge together with no problem if they are similar in size.
Derek.
AnswerID: 320415
Follow Up By: Member - Roachie (SA) - Tuesday, Aug 12, 2008 at 20:01
I agree with what Derek said. The only addition I would make would be to add a manual switch to allow you to over-ride the solenoid if ever it's needed. This switch would best be accompanied by a BRIGHT red or green light, so you are aware the switch is ON.
It would be handy for cold morning cranking duties etc (especially if it's a diesel).
FollowupID: 587249
Follow Up By: Member - Davoe (Yalgoo) - Tuesday, Aug 12, 2008 at 20:41
Instead of bright colour you just get one of those spring switches so it has to be held on
FollowupID: 587259
Reply By: Gazal Champion - Tuesday, Aug 12, 2008 at 17:26
Hi Poida,
I purchased a unit from Supercheap for $99.00.
It came with heavy duty wires to connect the 2 batteries and a control device which disconnects the aux battery from the starting battery when the voltage in the starting battery drops below 11.5 and will not reconnect the aux battery till the voltage in the starting battery gets up to 12.5 volts or there abouts.
It also comes with a good set of instructions.
It is in a neat little package, solenoid and activation circuit, and I thought it was excellent value for that money.
I have been using it for about a year now, 5 days a week at least and I am very pleased with it.
Derrick from ABR might have a better quality unit so I would seek his advice, or where offered, consider it in depth. It is free advice and is worth a whole lot more than you pay for it.
Regards,
Gazal.
AnswerID: 320424
Follow Up By: Gazal Champion - Tuesday, Aug 12, 2008 at 17:32
Should have added that it isolates the aux battery at start up so that the 2 are not connected during starting.
It is called "Calibre Battery Isolator Kit".
Gazal.
FollowupID: 587216
Follow Up By: oldtrack123 - Tuesday, Aug 12, 2008 at 21:01
Gazal
THOSE operating voltages don't give you much protection in my opinion . Most vsr for bat paralleling operate @ approx 13. 2 0r higher for cutting in[ this means crank has some charge put back before aux is switched in. they also drop out @ 12. 6v approx to protect the main from being discharged ie keep it as fully charged as possible for engine stsrting. The one you have is the more common one to protect bats from over discharging not that regular discharging any wet lead acid to 11.5v is good for it's long life.
FollowupID: 587266
Follow Up By: Gazal Champion - Friday, Aug 15, 2008 at 18:51
Sorry Oldtrack,
I was shooting from the hip with those voltages.
I have rechecked the info sheet which came with the kit and it says that the cutout voltage is 12.5V and the cutin voltage is 13.5V.
I have had it for a year or so now as I said above and have not experienced any problems at all even with the Waeco going 24 hours a day during hols. Mind you the second battery is an N70.
FollowupID: 587584
