Will it fit??
Submitted: Wednesday, Aug 13, 2008 at 10:07
Sir Kev & Darkie
Now that I have the new drivers
seat fitted into Darkie, I am thinking of using the old drivers
seat and mounts to fit it on the passenger side. So as I can get rid of the 2 seater bench
seat.
My question is will the mounts bolt straight up or will I have to fabricate new mounts??
I know the back rest adjuster will be on the wrong side for the passenger but I will be able to manufacture the new floor console to suit for access to it.
Cheers Kev
| Russell Coight:
Reply By: Rossco td105 - Wednesday, Aug 13, 2008 at 10:23
Hi Kev,
I think the rail on the drivers side of the drivers
seat is shorter than the rail on the passenger side. Both rails are the same length on the passenger
seat. Just went and checked on
mine (I swapped to a set of GXL seats so I could run a centre console instead of the third 'middle'
seat).
May have to swap
seat bases, not so easy? to do what you want. A GXL
seat from the wreckers may be the go if they'll sell it separately.
Ross.
320518
Follow Up By: Sir Kev & Darkie - Wednesday, Aug 13, 2008 at 10:28
Ross,
I may have to do some changing of mounts from the old passenger
seat to the driver
seat (hopefully it works)
I may end up checking the wreckers out for a GXL
seat as
well as it may end up being easier.
Cheers Kev
| Russell Coight:
587310
Reply By: Kiwi & "Grenade" - Wednesday, Aug 13, 2008 at 10:28
Is Sam complaining that she isnt being looked after huh!?!
Give her a milk crate!LOL!
and no Im not bludging.....Ive cleaned my house, and yours and glued ya shoes to the floor!!
320519
Follow Up By: Member - barry F (NSW) - Wednesday, Aug 13, 2008 at 10:34
Maybe if he left
the bench seat in she could sit closer & snuggle up to him!! ? LOL
587311
Follow Up By: Kiwi & "Grenade" - Wednesday, Aug 13, 2008 at 10:36
It would certainly make closer access for all sorts of mischeivious things to happen!lol!
587312
Follow Up By: Sir Kev & Darkie - Wednesday, Aug 13, 2008 at 10:40
2 kids is enough LOL
| Russell Coight:
587313
Follow Up By: Kiwi & "Grenade" - Thursday, Aug 14, 2008 at 13:57
you got a dirty mind kev...I wasnt thinking along those lines at all...!! LOL !!
587456
Reply By: Wayne's 60 - Wednesday, Aug 13, 2008 at 19:18
Hi Kev,
Have just completed a similar move of seats in the 80, driver's to passenger side. Had to take the
seat off the driver's mounts and put it onto the passenger's side rails. There may be some work involved in removing the plate that holds the (in non technical terms) the bit you plug the seatbelt into.
I'm still working through the
seat belt stalk issue at the moment.
FWIW, priced a GXL 80 series
seat............ $800.00 for a second hand
seat seemed a little pricey.
Hope this helps a little,
Wayne.
320599
Follow Up By: Sir Kev & Darkie - Wednesday, Aug 13, 2008 at 19:23
Wayne,
Thats sounds like an option.
I don't think the
seat belt stalk will be an issue as I think it is a seperate attachment in the 100 series seats.
Cheers Kev
| Russell Coight:
587367
Follow Up By: Wayne's 60 - Wednesday, Aug 13, 2008 at 19:46
Hi Kev,
I have limited knowledge of the seating and belts in the 100 so I hope you are able to sort this out without too many problems. I'm trying to source some (again in non technical terms) hard stalks, to save having to pick the end up off the floor.
What type of
seat did you purchase for the driver's side?
Wayne.
587371
Reply By: On Patrol (Project TONI) - Wednesday, Aug 13, 2008 at 20:12
Hey Kev!!!
Whats wrong with the Tojo
seat????
Not good enuff eh. He He He.
Cheers Colin.
320606
Follow Up By: Kiwi & "Grenade" - Thursday, Aug 14, 2008 at 13:59
maybe he shoulda got a patrol...!!
587457
Follow Up By: Sir Kev & Darkie - Thursday, Aug 14, 2008 at 15:40
PoooooooooooTrooooooooooooooools have schite seats as
well LOL
| Russell Coight:
587463
Follow Up By: Member - Bucky (VIC) - Friday, Aug 15, 2008 at 16:24
Hey Kev
Get a Patrol.....I did, but still have to "christen" it,....both in the Mud & shyte, and with SWMBO...... probably have the 22222222's
hehehehehehe
Bucky
587567
Reply By: autosparky - Wednesday, Aug 13, 2008 at 20:22
i think you will be able to bolt drivers
seat to passnger
seat rails the bolt pattern on the underside of the actual
seat to runners should be the same
320610
Reply By: rumpig - Wednesday, Aug 13, 2008 at 21:40
the seatbelt stork in the 100 series is bolted to the
seat itself, i know cause i have removed my 105 series seats and replaced them with SAAS seats both sides instead. the rails are different lenghts on the the left and right sides of the seats, once again i know cause i made my own bases up to fit the new seats on.
you can buy a secondhand GXL
seat like mentioned earlier, if you have a fat cheque book. the passenger side seatbelt has a belt type stork that bolts to the
seat, not a stiff stand alone type like what your drivers side bolts to. the centre
seat has a stiff stand alone type stork, but doesn't except the passengers or drivers seatbelt. below is a link to a thread i did on my install.
http://www.4wdmonthly.com.au/forum/showthread.php?t=56826
320629
Follow Up By: Wayne's 60 - Wednesday, Aug 13, 2008 at 23:41
G'day Rumpig,
Many thanks for the extra information.
When I have sorted the seatbelt issue I will post the relevant information.
Wayne.
587408
