who gets this "security warning" message on forum ?
Submitted: Wednesday, Aug 13, 2008 at 11:41
ThreadID: 60743 Views:3034 Replies:6 FollowUps:6
Was wondering if anyone is getting the following "security warning" message at each change of page on the forum.
I click on either 'yes' or 'no' and I can open new page.
Image Could Not Be Found
(yes, have advised EO and advised to ask here)
Using McAfee Security Centre.
Mainey . . .
Reply By: Member - John (Vic) - Wednesday, Aug 13, 2008 at 11:47
Nope!!
AnswerID: 320523
Reply By: Member - Madfisher - Wednesday, Aug 13, 2008 at 11:59
No.
Cheers pete
AnswerID: 320527
Reply By: ExplorOz - David & Michelle - Wednesday, Aug 13, 2008 at 12:15
I have one computer using McAfee and I have not seen this message even with the default settings. It is a McAfee message I think however try adding http://www.exploroz.com to your browsers trusted sites list in TOOLS - INTERNET OPTIONS - SECURITY - Trusted Sites - Click Sites and add http://www.exploroz.com. You should not have to do this however it seems to be where the message may be coming from.
Good luck - David
AnswerID: 320528
Follow Up By: Mainey (wa) - Wednesday, Aug 13, 2008 at 12:34
David,
yes, it advised me I had to add an "S" to be "https://"
it would not allow just 'http://' to be added, the "s" it says denotes a 'safe' site.
I have rebooted and the security message still remains .. grrr
Mainey . . .
FollowupID: 587319
Follow Up By: ExplorOz - David & Michelle - Wednesday, Aug 13, 2008 at 12:46
OK go to the same place and before you hit add - un tick the little box at the bottom that says Require Server Auth ..... and see how that goes - it will alow you to add it then.
David
FollowupID: 587320
Reply By: Mainey (wa) - Wednesday, Aug 13, 2008 at 12:45
it is W O R K I N G once again now
I added the "." (dot) at the end cause I left it out first time.
Can't figure it out as no other sites have it there either?
Thank you David.
Mainey . . .
AnswerID: 320531
Reply By: Member - Davoe (Yalgoo) - Wednesday, Aug 13, 2008 at 16:40
yes.......... and no
he work computer gives me that messege but my homeone just makes extra clicks like its connecting to some other sites I dont know about - Is it a virus?
AnswerID: 320571
Follow Up By: Mainey (wa) - Wednesday, Aug 13, 2008 at 16:53
Umm,
does it have "exactly" the same two internet address ?
as in the picture I have posted ??
Mainey . . .
FollowupID: 587343
Follow Up By: ExplorOz - David & Michelle - Thursday, Aug 14, 2008 at 15:21
Davoe,
Is the home computer Vista and using IE with McAfee?
I have noticed a second click using the above configuration when the page loads - it only started when I change a setting in McAfee (I will have to work out which one). There is no real reason for the second click and I do not know what is causing it - I will investigate.
Did the work computer fix itself with the message Mainey reported. I do not know why this .dll is loading anyway, and there is no bugs or viruses in the ExplorOz code. I will have to see what I can research about this also.
David
FollowupID: 587461
Follow Up By: Member - Davoe (Yalgoo) - Thursday, Aug 14, 2008 at 20:16
no it is windows XP
dont know what the work one uses but it comes up with 3 simular messages to mainys so i need to click no 3 times for each page etc i load up. I tried adding EO to trusted sites but that function seems to be disabled - could be a work computer thing
FollowupID: 587486
Reply By: Pyro 1 - Wednesday, Aug 13, 2008 at 21:44
Evening Mainey,
same problem here tried your fix with little success. Did you end up fixing problem or still going and did yours only start today.
Graeme
AnswerID: 320631
Follow Up By: Mainey (wa) - Wednesday, Aug 13, 2008 at 21:50
Graeme,
I did as David said, it has worked yippeee
It started yesterday.
Mainey . . .
FollowupID: 587398
