Toyota Efficiency
Submitted: Thursday, Aug 14, 2008 at 19:15
Member - Doug T NT
Had all oils changed at
Tully a few weeks ago, have travelled some 4300Klms , including 2215 Klms with the Caravan behind ,checked the engine oil today , Nil needed , the Troopy now has 724,000+ on the clock,
Reply By: Ianw - Thursday, Aug 14, 2008 at 19:27
Just shows how good OIL is these days!!
Ian
320710
Reply By: Member - Clive G (NZ) - Thursday, Aug 14, 2008 at 19:32
I guess you will be taking the “running in oil” out of it some time soon. LOL.
CliveG NZ
320711
Reply By: Member - Axle - Thursday, Aug 14, 2008 at 19:56
So you only check the oil every 4300ks??, thats confidence!!.
" OH!! What a Feeling!!."
Cheers Axle.
320718
Follow Up By: TD100 - Thursday, Aug 14, 2008 at 19:59
i never check
mine between 5k
services cos it never needs any!
587482
Follow Up By: Member - Axle - Thursday, Aug 14, 2008 at 20:46
You are a operator that needs replacing, if employed in the earthmoving industry!!.
Cheers Axle.
587491
Follow Up By: Member - Doug T NT - Thursday, Aug 14, 2008 at 20:52
Axle
I agree with TD100, if you know your vehicle and how it performs that's the way I have always operated, I do put trust in the gauges It has, and same applied to 30 years of Truck driving, I did own a 1959 FC ute , I new it burnt oil ( and did it burn it) so every day checked and added , but yes as a teen I bloody thrashed it,
587494
Follow Up By: TD100 - Thursday, Aug 14, 2008 at 21:18
Funny you had a FC as a teen so did i (58 FC
sedan) poor thing coped an absolute hiding hahahahaha Paul
587498
Follow Up By: Best Off Road - Friday, Aug 15, 2008 at 06:51
The mighty FC.
I had one as my first car back in 79. A beautiful one owner with 90,000
miles on it.
587514
Follow Up By: Member - Doug T NT - Friday, Aug 15, 2008 at 07:37
Best Off Road
And I bet you wished you still had it now , it would have been "Best on Road"
587519
Follow Up By: Member - Doug T NT - Friday, Aug 15, 2008 at 07:42
Here's a photo of the ute, and yes it had the white Pom Pom's around the rear window , of course todays youngers would have no idea what they were , the trend was to get some lace with little white balls dangling on it and push the lace in between the glass and the rubber , maybe some other oldie might have a photo of such, The name on the wheel spats was "Telstar"
Image Could Not Be Found
587521
Follow Up By: Member - Crazy Dog (QLD) - Friday, Aug 15, 2008 at 19:21
AND - would they be SLIM'S by any chance?
Grrr!!!
587592
Follow Up By: Member - Doug T NT - Friday, Aug 15, 2008 at 20:18
Crazy Dog
Next you'll be telling us that you had little balls too.
587606
Reply By: donk - Thursday, Aug 14, 2008 at 20:09
Now you have said how
well it is going it will probably have a problem
Regards Don
320722
Reply By: Kroozer - Thursday, Aug 14, 2008 at 20:13
Awesome, has the motor ever had any work done to it? Does it blow much smoke or run hot ever. Just interested as
mine has just ticked over 300,000 and has started to lose power and blow smoke. Just interested to know what you have done to get that amount of k's out of yours.
320723
Follow Up By: Member - Doug T NT - Thursday, Aug 14, 2008 at 20:47
Kroozer
Had the Fuel Pump changed at 345000 and even then I think the mob in the Isa wanted a job , anyhow it was done and I paid, had the Valves check at Prosser Toyota in Gosnells WA 18 months back , nothing needed fixing and it's still on the original Injectors,
It has had a lot of long runs as a Pilot vehicle, I always add Wynnes or Nulon to all oils when changed , and occasionally I add Wynnes Spitfire Injector Cleaner to the fuel.
587492
Reply By: Robin Miller - Thursday, Aug 14, 2008 at 20:16
Thats good Doug , they are suprizing these days , and I have been surprized that my Patrol hasn't seemed to have used a drop in 160,000 and the only reason I changed the plugs at 130,000 was because I thought I should !
320724
Follow Up By: Member - John (Vic) - Thursday, Aug 14, 2008 at 21:15
Robin were they those Platinum Plugs??
My Turbo Falcon has the things and according to the owners manual they are good for 150K before changing.
Shudder to think how much they are gunna cost when they do need to be changed.
587497
Follow Up By: stefan P (Penrith NSW) - Thursday, Aug 14, 2008 at 21:51
john I had platinum plugs in my cressida, about $20 per plug a few years back
587501
Follow Up By: Robin Miller - Friday, Aug 15, 2008 at 08:05
Hi John
There even better, Iridium tipped I think - anyway they were only a dollar dearer than normal at $9.95 each. Not that it makes much difference what sort you use as long as heat range is ok.
One of my favourite posts from the Patrol website was when someone trying to put a case for diesel said that they would cost $100 each.
587526
Reply By: Member - John (Vic) - Thursday, Aug 14, 2008 at 21:17
Good run Doug hope you haven't mozzed the thing by telling us how good its been :-)
I reckon its the nice long continuous runs you did as a Pilot that makes the difference.
320734
Reply By: troopyman - Friday, Aug 15, 2008 at 15:31
Is the motor non turbo ?
320791
Follow Up By: Member - Doug T NT - Friday, Aug 15, 2008 at 15:56
troopyman
Yep,,,
587562
Follow Up By: troopyman - Friday, Aug 15, 2008 at 21:15
Thats why . The motor produces so little horsepower it lasts forever . I do about 10,000klms per year in
mine so it should last until i am 150 .
587613
