DX Nissan Patrol 94 - child restraints
Submitted: Friday, Aug 15, 2008 at 10:01
ThreadID: 60780 Views:3689 Replies:5 FollowUps:1
We have a 94 DX Nissan Patrol 4.2 Turbo Diesel and are about to have a baby. We cant find any where to attach the child restraints to. Do these have to be installed, or should they be standard in the car already? Also, I plan to build a set of draws in the back and was wondering how I would go about this with the child restraint. Any comments and advise is appreciated.
Thanks, Jenko
Reply By: Member - John - Friday, Aug 15, 2008 at 10:31
jenko, should show where they are in your manual. They should be in the rear under the carpet, pull it back and have a look. Rear drawers negate the legal mounting points, as far as I know. Maybe talk to those that make the drawers? Good luck.
John and Jan
AnswerID: 320775
Reply By: Best Off Road - Friday, Aug 15, 2008 at 10:46
Jenko,
Give me a call on 03 9706 6527 and I'll explain how to find them and fit the child mounts.
Jim.
AnswerID: 320776
Reply By: Member - Dunworkin (WA) - Friday, Aug 15, 2008 at 10:55
jenko, the points are behind the rear seats in our '99 Patrol, we had draws put in ours therefore the points are under them but can still be used, however the points then become 'illegal' although workable. The reason is because of the belt going in under the drawers, in an accident, at the point of impact the corner of the draws could cut through the belt. I believe some people have used the points with draws anyway.
D
Simba, our much missed baby.
AnswerID: 320777
Reply By: Mick15 - Friday, Aug 15, 2008 at 15:10
Directly behind the back seat there are four bolt holes (6mm), 2 on each side, i had a length of 30x2 mm square tube drilled it to bolt into the holes, then tigged some peices of 5mm plate to it and milled a 13mm slot into each for the belt to clip into.
AnswerID: 320788
Reply By: jenko81 - Sunday, Aug 17, 2008 at 09:24
I had look in manual tells me everything but what i need to know, had a look behind rear seats there are two luggage ty down points do i have to unbolt them and use those existing holes, makes sence to me
AnswerID: 320963
Follow Up By: Member - Ed. C. (QLD) - Sunday, Aug 17, 2008 at 11:44
Jenko, with a DX, I presume you have a rubber mat instead of carpet in the cargo area?? Either way, you'll have to lift this (at the front) and fold it back...
Approx. 220mm in front of the bolt holding the luggage tie-down, and directly in line, you should find a captive nut in the floorpan (should be one on each side).. There will probably be a plastic "nut cover" in there which you'll have to prise out.. These are your child restraint anchor points..
Be aware that, unlike all/most of the other captive nuts in the Patrol body (which have metric threads), these have an imperial thread (5/16 UNC)...
Hope this helps:)
Regards, Ed C
Confucius say.....
FollowupID: 587770
