How can I fit a single seat in the 3rd row of my GQ?
Submitted: Friday, Aug 15, 2008 at 18:32
ThreadID: 60786 Views:2910 Replies:2 FollowUps:4
Is it possible to put in a split rear seat into the back of the GQ, like the one from the GU?
The normal factory bench 3rd row seat in the GQ needs to be a single seat.
We have put in a fridge slide etc, and would like to have one seat beside it.
If anyone has done this before, or know how / have tips etc it would be apprecaited.
Reply By: Member -Toonfish - Friday, Aug 15, 2008 at 18:51
im pretty sure diamond had a setup like that i will find out and post later
2013/14 around oz adventure bound
AnswerID: 320817
Follow Up By: Kylie in the exy - Saturday, Aug 16, 2008 at 20:27
Excellent!
I look forward to it.
Thanks Toonfish ;-)
FollowupID: 587738
Reply By: Member -Toonfish - Monday, Aug 18, 2008 at 20:03
still waiting mate~!
AnswerID: 321183
Follow Up By: Member -Toonfish - Wednesday, Aug 20, 2008 at 21:46
sorry to tell you mate he had this setup in his jackaroo
but im sure it could still be done
wonder if gu brackets for rear seat will fit in gq rear? check the wreckers take a tape measure or paper fora template to try it?
FollowupID: 588333
Follow Up By: Member - Roachie (SA) - Wednesday, Aug 20, 2008 at 22:49
I think it would be a HUGE task. The GQ doesn't have the same captive nuts on top of the wheel arches, to which the GU seat (outer side) would have to be anchored. Also, the floor anchor point is totally different.
The engineers would have a field day with you....sending you into a tail-spin with a million rules, regulations, ADRs and other miscellaneous excuses as to why you can'd do it.
Sorry, but good luck with it all the same.
Roachie
FollowupID: 588348
Follow Up By: Kylie in the exy - Thursday, Aug 21, 2008 at 12:01
Thanks anyway guys.
Roachie is right. The GQ bench seat folds forward and the GU split folds to the sides. GQ has nothing available to attach seats to the sides.
Thanks Toonfish for following up.
FollowupID: 588387
