02 d22 navara
Submitted: Friday, Aug 15, 2008 at 20:51
stubbsy351
g'day all, im after some advice, i have a 3.0l td navara with 115,000km on the clock.currently it is jerking/chugging at arount 80 km/h in 4th gear, the engine is serviced by the book and has recently had a
fuel filter change with no change to the prob. any ideas would be great.
cheers!
Reply By: Dirty Smitty - Friday, Aug 15, 2008 at 22:08
Do you get any feel of this through the steernig wheel? Did you change the filter yourself? Does this occure after 80 km/h? Does it only occure in 4th gear?
Sorry for all of the questions but the answers to these questions may assist in a diagnosis..
Good luck
Stubs
Regards,
Dirty.
320843
Follow Up By: stubbsy351 - Saturday, Aug 16, 2008 at 08:03
the feeling is through the whole car (jerking) yes i did change the filter myself, it hasnt had any effect on the prob, and yes it only occurs in 4th at around 80 km/h.
thanx
587663
Reply By: Member - Bucky (VIC) - Saturday, Aug 16, 2008 at 03:38
Stubbsy
If my memory is correct 80 km/hr is 3,000 revs.
What does she do if you were to take her up to somewhere near the "red line", say 4,000 revs + ?
So does it do the same thru the gears, at those revs, or is it higher ?
Are there any engine management lights coming on ?
Have you had sensor's checked ie MAF, and exhaust (if there is one)
Bucky
320859
Follow Up By: stubbsy351 - Saturday, Aug 16, 2008 at 08:09
80km/h is aprox 2600rpm, the prob clears out if i "rev through it" so to speak at around 100 km/h and it also stops if i select 5th gear, there are no eng lights coming on although the boost gauge starts to "flick" at the same time. i have not checked any sensors apart from checking for leaks. they run a map/boost sensor, if that is useful?
regards
stubbsy
587664
Follow Up By: Member - Bucky (VIC) - Sunday, Aug 17, 2008 at 04:31
Well I'll be buggered.
See forgotten already..
Can't wait till I get Alzhemer's properly, and I get to meet new friends every day..
Bucky
587748
Reply By: bushy04 - Saturday, Aug 16, 2008 at 09:56
Had a simlar problem with my courier, check the lint filter on the injector pump?
Bushy
320882
Follow Up By: stubbsy351 - Saturday, Aug 16, 2008 at 20:19
g'day mate, what is the lint filter and where would i find it on a navara injector pump?
cheeres!
587737
Reply By: bushy04 - Saturday, Aug 16, 2008 at 21:47
Hey Stubbsy not real familiar with the navara, but on the courier it is where
fuel line goes into the pump.
The whole idear is that it is a gauze mesh to catch anything coming from the
fuel filter.
Until a couple of weeks ago I had never heard of them until the power dropped and I got a intermitant miss.
The local mechanic pulled and replaced the
fuel filter, then had to look further to find the problem.
It was a ball of lint in this filter wich sucked flat and blocked the
fuel.
Hope this helps Bushy.
320938
Follow Up By: stubbsy351 - Saturday, Aug 16, 2008 at 22:08
cheers mate i will have a look toworrow, hopefully that might be the cause
587741
Follow Up By: stubbsy351 - Sunday, Aug 17, 2008 at 10:04
gday mate, had a look this morning and the nissan doesnt appear to have one? thanks for the advice anyway
stubbsy
587765
Follow Up By: alldylan - Sunday, Aug 24, 2008 at 23:04
Hey stubbsy, sounds like a fuel problem this would cause the chugging. I would check the fuel filter lines make sure they are tight so there is no air leaks.
BTW I found a new Aussie Navara
forum www.navara.asia
588996
Follow Up By: stubbsy351 - Tuesday, Aug 26, 2008 at 12:25
have just taken it to a mechanic and he reckons that its because its got a non genuine fuel filter and its sucking air? any one heard of this happening??
589251
Follow Up By: stubbsy351 - Tuesday, Aug 26, 2008 at 12:27
buy the way its got a 2 week old ryco filter in it
589252
