tirfor/roof top tent?
Submitted: Saturday, Aug 16, 2008 at 09:18
ThreadID: 60806 Views:2950 Replies:3 FollowUps:0
just a question does anyone have a user manual for a tirfor T508 and know what size cable it uses? Also does anyone got any feedback on the rooftop tents for sale on ebay?
ryno
Reply By: Ray - Saturday, Aug 16, 2008 at 09:42
Hi. I've been around Tirfors for some time> I do not know the full specifications for your model but I can tell you that you do not use ordinary wire rope. You will require extra hard wire rope which I believe can only be purchased from Tirfor and is specially swagged at one end to make threading through the machine easier and a hook at the other end.
Do not use any other handle than the one supplied and always use genuine shear pins and never lengthen the Tirfor rope by using bulldog clamps.
Lifting capacity is 50% of pulling capacity but this can be varied with the use of snatch blocks and pulleys. ( I have actually moved a 50 ton mill shell with a 5 ton Tirfor by using snatch blocks and pulleys but it was very slow)
AnswerID: 320879
Reply By: kcandco - Saturday, Aug 16, 2008 at 20:58
Hi Ryno
This site may be some help
http://www.highgearsales.com/Tirfor21.html
regards Kc
AnswerID: 320934
Reply By: Ted (Cairns) - Monday, Aug 18, 2008 at 12:08
I've got one of these roof top tent
Bought it a while ago from a different seller for $499 plus $120 freight. Couldn't be happier. I needed to drill some holes in the ladder to allow adjustment to lower heights (I have it on the trailer at the moment), which is a 5 minutes job.
I suppose a Howling Moon has somewhat better canvas, but it's nearly 5 times dearer!
I've seen the new models with extended entry fly etc., but I think it's just added complications - defies the purpose of having a quick to erect tent. And takes away the view, offering "privacy" instead - as I use it in secluded areas I'd rather have the view thanks!
Ted
AnswerID: 321102
