Generators, which one
Submitted: Saturday, Aug 16, 2008 at 17:23
Member - Moo
Hi all just after information on power from generators in general.
We want to buy one that will run our air conditioner in our van,From the archives i notice the brand Kipor mentioned,We have seen one of these and they look good .The questions is can you start your air conditioner off your battery in the van then change over to your generator as I believe from reading you need more power on start up than actually running time?
If this can be archives then would a 2KVA generator be suffice?
The salesman person stated that running a van air-conditioner we should not get anything less than a 2.6 KVA is this true?
Reply By: PeterInSa - Saturday, Aug 16, 2008 at 17:41
Moo,
The most popular generator that I have comes across in the bush is the Honda 20i or the Yamah 2.4. The Honda will run our Commander A/C, but I am not sure that it will run the latest Commanders.
The Yam 2.4 is quiet a bit heavier and more bulkie, but seems to run the lastest A/C. I would buy a Honda again but would try out before buying.
Other brands are cheaper than these two units, but the Honda and Yam are proven.
320917
Reply By: Cram - Saturday, Aug 16, 2008 at 18:21
I purchased a cheap sinewave gene about 18 months ago. I have only used it half a dozen times. I went to use it a little while ago and it would not start. I had pulled it apart and found that the
fuel hose had perished and I have been flat out trying to find one to replace it.
When I got it back together it still would not start. Cost of labour if I put it into the
shop is prohibitive.
So simply for me the moral of the story is buy one of the trusted brands. Yes more expensive but worth it in the long run.
320922
Follow Up By: Member - Olcoolone (S.A) The O - Saturday, Aug 16, 2008 at 20:05
So true, we have 3 Honda EU20i's in our service vans that get a hammering and never had a problem, always start first pull.
Easy to get parts for them as they are supported by Honda Australia.
Yamaha is another good brand and seems to be a little quieter then the Honda's.
With Honda or Yamaha you can't go wrong and with support from their parent company as a bonus.
I'm always skeptical about other brands that aren't bought into Australia buy a large manufacture like Honda or Yamaha, will you still be able to get parts and service in the future, what happens if the importer goes through the hop or worse still if the manufacturer in China goes bust.
With Honda or Yamaha you pretty safe knowing they are going to be around for years to come.
587736
Reply By: Best Off Road - Saturday, Aug 16, 2008 at 20:11
What size A/C do you have Moo?
The Heron 2.2 will happily run off a 2000 watt Honda or its copy, Kipor.
The Heron 3.0 will not.
Jim.
320929
Follow Up By: Member - Moo - Tuesday, Aug 19, 2008 at 21:55
Hi Jim we are running and air commander. Thank you for your comments ,we ended up going for the Yamaha 2400is.
the blue kipor which is now run by primus I belive is good with its country wide warranty but yamaha is knowing.
588181
Reply By: hunter40 - Sunday, Aug 17, 2008 at 14:16
Hi Moo,
I have a heron 3 and I run it on a Yamaha 2800 with the battery charger and fridge and tv ect.. running at the same time it has no problems at all I get about 12hr continous running on a full
tank
Cheers Lyle.
320985
Reply By: deserter - Sunday, Aug 17, 2008 at 15:55
Your first question - can you start the air-con off the battery - I expect the answer is no.
320993
Reply By: Member - Christian P (WA) - Monday, Aug 18, 2008 at 11:29
I have been recently looking for a genset myself, I figured the competition was between the Honda Yamaha and Engel, I ended up going with the Engel, the reason being I was told that they use a Honda motor, the SHX 2000 retail for $1699 and I found a business in Qld selling them for $1130 brand new, so I ordered one, even with postage from QLD to
Tom Price I saved $500.
321095
Reply By: Member - Moo - Tuesday, Aug 19, 2008 at 22:04
Thanks to all that replied. We have purchase a yamaha 2400is and I must say the five star yamaha cycle in WA were very professional in their service
321341
Reply By: puttputt - Sunday, Aug 31, 2008 at 22:08
I like the Yamaha 2400, but all Yamaha's are only rated at 230V, and not 240 V, this will drop effiency on equipement and cause them to run hotter, any comments
323191
