Cruiser 1-HZ engine running like a chaff cutter
Submitted: Monday, Aug 18, 2008 at 04:37
desertdweller
Hi everyone,
My bus is running extremely rough, for 5-10 mins . When started for the first time. No matter what time of the day. Blows a heap of white smoke out the exhaust aswell. After 5-10 mins she runs like a trooper, for the rest of the day.
I've tried glowing it a couple of times beforhand, replaced the glow plugs, did the injectors 8000 km ago and did the
fuel and air filters.
If there's anybody out there who's had simular problems or has any handy hints to help me out. I'd appreciate it greatly.
Cheers Greg
Reply By: Member - Bucky (VIC) - Monday, Aug 18, 2008 at 05:25
I'm not an expert here, but I would believe that it's either your glow plugs , again, or maybe try replacing the relay, for the plugs..
I have a similar type problem with my Patrol, and it's gunna be the relay, I replace first, if I ever get around to it....
Bit embarrassing ain't it...the guy's at work give it to me, at knock off time...
One thing I have tried is to give the truck 2 or 3 hits on the key, waiting for the glow plug light to go out each time.
Bucky
321068
Reply By: howesy - Monday, Aug 18, 2008 at 09:44
Get a mulimeter and check that voltage is actually getting to the glow plugs when you glow it. (should go about 5 secs or so) If there is no voltage when someone turns the key to glow it for you then you relay?timer nedds to be looked at.
If voltage is present when glowed then loosen the nuts on the glow plugs and slide out the connecting bars so all glow plugs are now independent of each other then set the multimeter to the 200 ohm setting and put one prong on the centre threaded part of the plug and scratch the other on to the side body of it. the reading on the multimeter should go from 1 to pretty damn close to 0.00
If any of these after checking and rechecking(in case you had bad contact with your probes) dont go to 0.00 then that plug has died.
glow plugs are like any electrical item sometimes they dont last long for no reason, I only ever replace one at a time and I dont do that very often only replaced one in last 2 years in my 1HZ got it a few months ago for around $17 from Bursons
321084
Reply By: Member - Serg (VIC) - Monday, Aug 18, 2008 at 10:05
Greg,
I would check compression, particularly considering you have white smoke. IMO glow plugs have nothing to do in 1HZ – at some stage I have completely disconnected
mine without any ill effect, just one more crank. They truly needed in sub-zero temperature to help start, but has very little to do to roughness of cold engine. High-pressure pump is another possibility. You can hold each injector line to feel “knocking”. They should feel very much the same and be sharp. It gets some practice to feel them properly. If you notice that particular one feel “soft”, then exchange injector with “sharpest” one and repeat observation next morning. If “soft” one migrate with injector, that it is definitely injector, otherwise seems like
fuel pump. If all knocks fairly equivalent, that it most likely compression or valve/injection timing.
Good luck
Serg
321086
Reply By: Nav 8 - Monday, Aug 18, 2008 at 10:31
White smoke and rough running can also indicate
water entry into the combustion chamber....Nav.
321087
Follow Up By: Tim HJ61 (WA) - Monday, Aug 18, 2008 at 10:55
which then clears as all the
water is pumped out of the cylinder.
Pressure from the
water jacket seeps in after the engine is turned off. It may not show up as bubbles in the radiator when the engine is running depending on the size and location of the gasket leak. In a petrol engine, you can take the radiator cap off to reduce the pressure after you have shut down and see if it makes a difference on the next start up. In a diesel, I suspect that for enough
water to be there to cause rough running then you're much more likely to be bending conrods and it won't run properly again.
I'd be following the glow plug avenue as a start,
587900
Reply By: taswegian - Monday, Aug 18, 2008 at 18:08
Hi greg,
Remove glow plugs, put newspaper with a piece of rag sitting on top over each hole, leave over night grank engine over next morning check paper for
water you will have your answer.
Cheers, Taswegian.
321154
