landcruser fuel use
Submitted: Monday, Aug 18, 2008 at 15:30
ThreadID: 60859 Views:2453 Replies:5 FollowUps:3
Just wondering if anyone knows the differences between fuel consumption with 4.2 diesel auto/manual/turbo and non turbo looking at byeing around a 2002 model
Reply By: Member - Graham H (QLD) - Monday, Aug 18, 2008 at 18:05
I have a 4.2 TD Auto and towing my 2.8 tonne van at 100kph I get about 6k per litre or 16l per 100k. (1HD-FTE) 151kw 430Nm
I believe the non turbo uses more as its only about 2/3 the power of the turbo engine. (1 HZ) 96kw 285Nm
Others posters will probably differ
AnswerID: 321150
Reply By: Sir Kev & Darkie - Monday, Aug 18, 2008 at 18:11
With a 4.2 NA slug towing a very heavy trailer (about 2t) and sticking to the speed limit ;) Darkie used about 20L/100km and that is with 285 tyres
Cheers Kev
Russell Coight:
AnswerID: 321155
Reply By: Member - Phil G (SA) - Monday, Aug 18, 2008 at 19:40
The Government's combined figures are good for comparison:
HZJ105 Manual (non-turbo) 13.0 l/100k
HDJ100R Manual (TD) 11.0 l/100k
HDJ100R 5-speed auto (TD) 11.2 l/100k
AnswerID: 321171
Follow Up By: Kylie in the exy - Thursday, Aug 21, 2008 at 13:14
Hi Phil,
Can you show me where to find this information on the net? I am comparing the GU Diesel 3ltr to the LC's.
Also, can anyone confirm that is was just the series II that were handgrenades? If I go series III I should be ok?
The equivalent LC is a few more $$ that I dont have.
FollowupID: 588393
Follow Up By: Member - Phil G (SA) - Thursday, Aug 21, 2008 at 23:11
Kylie,
I mostly go to http://www.redbook.com.au/ and look up the used car value for the vehicle, then click on the specifications. Provided the vehicle is after about 2002, the "combined" fuel consumption figures are usually listed.
FollowupID: 588497
Reply By: qubert - Monday, Aug 18, 2008 at 21:02
i put a turbo on my 1hz and now get about 50 km extra on a tank of fuel. ( thats if i dont feel like using the extra horsepower)
AnswerID: 321205
Reply By: Crackles - Tuesday, Aug 19, 2008 at 07:16
As a comparison in sand the 1Hz used 107 litres to cross the Simpson & the TD used 90. (Both manuals)
Cheers Craig.............
AnswerID: 321241
Follow Up By: ross - Tuesday, Aug 19, 2008 at 09:09
My HZJ75 with 1HZ uses 12.5/100 averaged over many tanks with no load on
FollowupID: 588056
