ozi explorer on gps
Submitted: Monday, Aug 18, 2008 at 21:15
ThreadID: 60873 Views:2181 Replies:2 FollowUps:3
hello . can i intergrate ozi explorer onto my street navigator so it displays my current position when i am out bush - without using a laptop. (my nav works on windows stuff.)
Reply By: Member - Rob S (NSW) - Monday, Aug 18, 2008 at 21:38
More info need on what type of navigator you have.
If it is running at least Windows mobile 3 and has a sd card slot and usb cable to connect to your pc
you should be able to get it to run Ozi explorer ce version for mobile devices.
Rob.
I only ever made one mistake
AnswerID: 321215
Follow Up By: qubert - Monday, Aug 18, 2008 at 21:45
yes it has all of those . its a cheaper one called 'laser navig8r'. it was cheap but it does some things that the expensive ones wont do ( my bro bought a uniden and it has less features than my one )
FollowupID: 588018
Follow Up By: HGMonaro - Monday, Aug 18, 2008 at 21:56
ok, ignore my answer below... I was a bit slow replying!!!
my elcheapo GPS runs from the SD card. Most that do this seem to be able to run Ozi, mine does. Take the SD card out and turn it on... if nothing works then it's probably the same. Confirm that and I'll explain what I did to get Ozi running.
Nige
FollowupID: 588022
Reply By: HGMonaro - Monday, Aug 18, 2008 at 21:50
If this is the Navway "Street Navigator" then page 52 of the downloadable "Hardware Operating Instuctions" manual says you can, although it doesn't give a great explanation on how to do it.
Cheers, Nige
AnswerID: 321221
Follow Up By: qubert - Monday, Aug 18, 2008 at 21:56
it currently has maps oon it made by NAVTEQ
FollowupID: 588024
