2003 Hilux 5L-E slow as buggery
Submitted: Monday, Aug 18, 2008 at 21:25
jaybz75
Hi all. I have just bought a 2003 Hilux d/cab 4x4 5L-E. Has 220K km on the clock.
It has been a geo's car up in Telfer but is in suprisingly good nick apart from a rooted clutch and stuffed tires which i have fixed, and also the 20kg of red dust that i had to pull the entire cab apart to get rid of.
I just gave it a full service inc g/box, transfer case, diffs, timing belt, clutch/brake fluids and filters all round.
The motor starts and runs fine but the problem is is that it is as gutless as anything. I hit the smallest
hill and have to drop back 2 gears.
I had a 97 3L hilux before this one with 350,000kms on it and it had loads more power than this one.
The motor is sound, doesnt burn any oil or have any death rattles and i have noticed when following it that it doesnt have any black smoke coming out the exhaust, even when hard into it going up
hill.
Hope someone can help as its a bitch to drive with <60hp..
Reply By: qubert - Monday, Aug 18, 2008 at 21:36
when where the valve clearances checked
321214
Reply By: qubert - Monday, Aug 18, 2008 at 21:41
correction--- look at youre
fuel pump, that red dust is very fine and contains iron, that has the ability to pass your filters and 'chew' away at the aluminium housing on your pump. it should blow a little black smoke. you could try a cheaper experiment and put an electric pump inline to get the
fuel there easier.
321217
Follow Up By: jaybz75 - Monday, Aug 18, 2008 at 23:34
Thanks for the reply qubert.
I havent looked at the valve clearances yet. I guess a valve could have tightened up a bit but there isnt really any associated "putting" noise from the exhaust. Do these engines have tappets or shims?
You might be right about the
fuel pump, though i hope not because that straight away means big bucks. I would have thought there would be damage to the injectors themselves if lots of red dust had gotten past the filters causing black smoke from unburnt juice, which there is none.
I cant adjust the
fuel delivery on the 5L-E either like on the 3/5L, its all up to the EFI. I have a spare
fuel pump off a petrol rodeo that i might hookup to test your theory.
Is there a DIY injector pump kit for the 5L-E? I'm pretty handy with the tools.
588040
Reply By: ross - Tuesday, Aug 19, 2008 at 09:24
Maybe your
fuel injection needs a good service. I doubt an inline pump will increase pressure at the injectors
321256
Reply By: Member - Scooby (WA) - Tuesday, Aug 19, 2008 at 09:47
My 5L has just ticked over 200,000 and has never had the valve clearance's (shims) checked. I have approached two different diesel mechanics about this and they both said "if the valves are not noisy don't worry about it". They are easy enough to check yourself if you have a manual.
What did make a big difference was I recently had the pump timing checked and adjusted, it was a long way out.
The other thing that has made a difference to power and economy is fitting gas (approx 20% according to the dyno). After the $3000 rebate from the government (I'm in WA) it only cost $800.
Scooby
321261
Follow Up By: Stephen M (NSW) - Tuesday, Aug 19, 2008 at 15:53
Scooby,referring to the valves, they wont get noisy as they tighten themselves up not loosen them selves, and its quit common for them to do it. The valves were done twice on my old 2.8 and both times were out of spec. They are shim and bucket set up. Regards Steve M
588101
Reply By: Nav 8 - Tuesday, Aug 19, 2008 at 10:15
There is a couple of things you must check. Did you fit the new timing belt yourself? The fitting of this belt has to be spot on at all points eg, crank pulley, cam pulley and injector pump pulley. Just one notch out and you have a problem.
I would assume as you have serviced it that you have replaced the
fuel and air filters as both can cause this problem. The other thing to check is the
fuel delivery to the filter as there could be a restriction in the line from the
tank eg, blockage or squashed pipe. Take the
fuel line off at the injector pump side of the filter and using the
hand pump on top of the filter make sure you have a good flow of
fuel. The only other things that have to be considered and I hope is not the case is, the injector pump itself or being an ex
mine vehicle the engine has been dusted. This is a term used to describe an engine that has been ingesting dust through the air intake and has worn the rings out causing a lack of compression. You can only check these last two by taking the vehicle to a diesel workshop where they have the gear to do the job. Hope this helps solve your problem.. Regards Nav.
321262
Reply By: Member - Porl - Tuesday, Aug 19, 2008 at 11:32
and post this query on the Overlander
forum site, you'll get good info from Ferrit who i think grew up playing with nothing other than Hilux parts, and still does.
I've got a 5LE after a Prado RV6 and to be honest with around half the power and 2/3'rds of the torque specs, they drive pretty much the same to me. Bit different when you put the foot down but that's not my driving style or I wouldn't have bought a diesel.
So keen to know about your solution.
321268
Follow Up By: jaybz75 - Tuesday, Aug 19, 2008 at 14:02
Thanks for the reply's guys.
I dont think i can adjust the pump timing Scooby as
mine is EFI and yours is a mechanical pump. I dont know why they went EFI as there was nothing wrong with the prev design and its not exactly a high tech common rail multi valve engine. The gas sounds like the go but i have to get this prob sorted before any performance enhancing goes on. I didnt think the benefits of gas on a nat aspirated diesel was meant to be all that good. 20% extra is huge!
I did the timing belt myself Nav 8 but it was done properly. I've done a 2 3L"s previosly. It had the same amount of dismall power before hand anyway so i can rule out timing as an issue.
Initially i thought the donk had been dusted too but after 2000km it hasnt burned a drop of oil. I did whip the glow plugs out the other day to give it a compression test but blew my petrol tester to smitherines. Another lesson learnt the hard way.
The line isnt blocked i checked. It still uses 12L/100km which is about right. It runs a bit hairy, just not nice and smooth like a goodun should. Another symptom that is worth noting is when it gets up to temperature it is harder to start and makes a bit of a clunk when she fires up. Like comp is low on a cyclinder and extra weight is placed on one end of the crank when it starts.
I'm going to pull the rocker cover off and check the clearances and if there ok i will whip the injector pump off and check it over, maybe runa kit through it. I'll let yuz know how it pans out.
588090
Follow Up By: Member - Porl - Tuesday, Aug 19, 2008 at 14:17
Well my 5LE with 140k on the clock and a high top ARB canopy otherwise relatively empty, gets 10L/100km or less no matter what I do, though i stay at or under 100km/hr.
The factory turbo was known to get the 12L/100km so there could be a
sign for you, perhaps.
Also, this is the link to my post here where i got a small bonus at work and decided to pump up my power a tad, got a chip for the 5LE which cannot be put on the 5L simply because it wasn't an EFI. I didn't want a turbo as the factory turbo had a stronger clutch and gearbox than the 5LE so I didn't feel a need to test my components with the aftermarket turbo though of course did not get the level of gains that comes with a turbo.
http://www.exploroz.com/Forum/Topic/59186/Hilux_30_non-turbo_Chip_Dyno_test.aspx?Print=1&fq=59186
By the look of that link you could find it at Post 59186 i suppose.
588096
Reply By: Member - Scooby (WA) - Wednesday, Aug 20, 2008 at 08:52
Hi Jaybz75,
Just to follow up on the power increase with gas on my 5L.
I am looking at the dyno graph, the figures are 48.5 HP and 122ftlb with gas off and 58.1HP and 145 ftlb with the gas on.
The dyno run was done before the pump timing was corrected so power and torque should be higher now, it certainly felt a lot better after the timing and new injectors were done.
Scooby
321369
Follow Up By: jaybz75 - Wednesday, Aug 20, 2008 at 10:47
Ooh those are stump pulling figures Scooby.
My Lister makes more grunt than that!
Well if that is what your lux is putting out then the theory of
mine making >60hp should be halved.
Jay
588237
Reply By: Member - Porl - Wednesday, Aug 20, 2008 at 11:33
And there was a post on here a short while ago about a post 2000 lux, buggered if i can find it now and am kicking myself i can't find the print out, saying it helps big time to manually clean something around the engine bay that gets full of oil and gunk, memory failing but thinking something about air intake manifold, gotta get my
gregory's out.
But the guy said he pulled an astonishing amount of cr@p out and it definitely helped economy and power as the air (i think) was terribly restricted.
321388
Follow Up By: jaybz75 - Thursday, Aug 21, 2008 at 00:19
I'll look into it Porl. There was a bit of crap around my intake butterfly when i pulled the inlet pipe off. Sort of a thick oily grease from the rocker vent i reckon but if i do pull the intake manifold off, there might be a whole lot more of it hidden in there.
Jay
588353
Follow Up By: jaybz75 - Wednesday, Sep 03, 2008 at 16:15
Well i finally found the problem.
I had a tight inlet valve on No 3 piston. All my exhaust valves measured .4mm clearance(cold) and 1 & 4 inlets measured .2mm, No 2 was .15mm and no 3 i couldnt get any feeler guage under it so i went to the engine
shop in Midland and swapped the shim for one 9 "thou" thinner which equates to about .25mm and when installed gave me .15mm clearance which is still tight compared to the .25 -.4mm clearances recommended in my manual but i'm not pulling the rocker cover off again.
The engine idles so much nicer now and is way quieter and has about 25% more power (up to about 30hp now). Much nicer to drive and hopefully wiill get a bit better
fuel economy.
Amazing what .4mm can do to a motor. The guy at the engine reco
shop reckons its not so much the valve
seat recessing in the head but the valve stretching, unusual for an inlet though he thought.
Thanks for the help everyone and i hope this post helps someone else out with a sililar problem in the future.
590718
Follow Up By: Member - Porl - Wednesday, Sep 03, 2008 at 16:20
Great news and that one will be printed out for my future reference file.
The exploroz thread on the manifold gunk on our 3.0D's was: 58917
590720
