Weekly Adventure Manual/Auto
Submitted: Tuesday, Aug 19, 2008 at 11:53
ThreadID: 60886 Views:3120 Replies:4 FollowUps:6
Well we seem to be getting ourselves into a weekly "lack of traction" adventure now that everything is soaked thru around Melbourne.
This time however is was with the company commodores and falcons.
I'm down checking on a football scoreboard project for which I am
designing a short range radio control link and on approach I note
that a large section of the Oval is part under water and the grass is
really slushy. So I park just of the bitumen path well away from water and do my thing and then get back into the car to drive off.
Sure enough despite the relatively solid looking appearance off the verge, just the weight of the car has caused underlying mud to seep up.
Start the engine and we don't go anywhere. Thinking now, I select 2nd in the automatic Commodore, apply a little handbrake and where out.
Easy, however I know the work crew is not far behind me so I head off to warn them. Get about 500m when I see them approaching and flash the lights but they sail past.
Quick U-turn and I catch them just as they parked exactly where I did.
They realize from wheels marks I put in the grass that this isn't good and try to get out, where apon they slide sideways on the gentle slope and embed the falcon ute further in.
I'm trying to give unheeded advice and it takes a while before they give up and give me the keys.
With 3 people we may have got it out by pushing but would have
made a real impact back at the office covered in mud, so instead
had a good look around.
Just at this time a bus load of school kids pull up and get out nearby !
Damm we really didn't needed an audience, espically this vocal one!
Noted that there was an ever so slight downhill slope behind the car.
So I thought, its like at the beach, you need to start rolling down toward the water for traction as sand is firmer - just don't go to far or turn to sharp!
I'm wishing however that the car was manual like my patrol as the
auto has almost no-feel in such slick conditions and you can't tell
when the wheels start to spin.
Jumped in the ute with plan to reverse in the direction of the slight slope.
(this slope was away from the road - so this had better work !)
Wheels began to spin and carefully applied increasing handbrake to transfer spinning wheels force to the non-spining wheels.
Of course both wheels started to spin, but with careful control got the car moving backwards and then kept it backwards until velocity increased enough to execute a large arc which brought the car back to the road to the amusement of all.
Reply By: Dasher Des - Tuesday, Aug 19, 2008 at 15:50
Theres nothing like an old dog showing off his tricks LOL
Well done old dog
AnswerID: 321287
Follow Up By: Robin Miller - Tuesday, Aug 19, 2008 at 16:14
Good call , you read between the lines , they were both 20-23
FollowupID: 588102
Follow Up By: Dasher Des - Tuesday, Aug 19, 2008 at 16:30
Young pups eh. Bit like the Old Bull/Young Bull routine
I drive a crewman crosstrak6 so I hopefully don't get into that kind of trouble. It would be nice to get some of that rain around here too
FollowupID: 588105
Reply By: Trevor R (QLD) - Tuesday, Aug 19, 2008 at 16:26
C'mon tell the truth, you just thought it would be a good time to revist your hooligan youth days didn't you? Bit of circle work on the wet grass I know your type.
LOL!!
Good story, lessons there for those that read it.
Regards, Trevor.
AnswerID: 321289
Follow Up By: Robin Miller - Tuesday, Aug 19, 2008 at 16:30
And Trevor, I knew that under our tough Hoon laws - they'd be dragging away the company car , not my Patrol.
FollowupID: 588106
Reply By: Member - Madfisher - Tuesday, Aug 19, 2008 at 17:28
Well done Robin. Does applying some handbrake also work on non lsd diffs?
Cheers Pete
AnswerID: 321301
Follow Up By: Robin Miller - Tuesday, Aug 19, 2008 at 20:46
Yep works there as well Pete !
FollowupID: 588162
Follow Up By: Member - Madfisher - Tuesday, Aug 19, 2008 at 21:02
Just goes to show you are never to old to learn something.
Thanks Mate
Cheers Pete
FollowupID: 588169
Reply By: Max - Sydney - Tuesday, Aug 19, 2008 at 20:17
Robin
You are too nice.
In your hooligan days you would have persuaded as many of the kids as possible to come and push you out - then when they are all lined up behind the car, floor it and splatter them with mud!
I well remember being caught on that trick by one of my Scout Masters in the Adelaide Hills in similar conditions - and the Morris 8/40 didn't have the power of a Falcon ute!!
Max
lol
AnswerID: 321325
Follow Up By: Robin Miller - Tuesday, Aug 19, 2008 at 20:48
Must Remember that trick for the next members gathering Max
FollowupID: 588164
