which shock goes where on a patrol???
Submitted: Tuesday, Aug 19, 2008 at 17:21
ThreadID: 60896 Views:2614 Replies:3 FollowUps:3
To those of you who are technically minded in this department it may seem obvious, but unfortunately I leave things I don't know about well alone.
Hence my question?
Which shock goes where on a GU patrol?
I have the original set of springs and shocks from when I bought the car 3 years ago. A friend needs new ones so I'm giving him them. They are no good to me, as I have a 4inch lift from ARB.
When I got them out of the shed I saw that one side is longer than the other.
Can anyone tell me which one goes where, as I will only be doing one corner at a time. (No hoist - Can't understand why the missus reckons we don't need one in the garage?. I guess we need the money for stupid stuff like food, insurance, healthcare.......etc)
Any help on what to most will probably be obvious.....would be greatly appreciated.
Brian
Reply By: Member - Roachie (SA) - Tuesday, Aug 19, 2008 at 19:58
Quote: "Which shock goes where on a GU patrol?"
The front shocks are both the same and the rear shocks are both the same.
I reckon you're probably referring to the springs (as opposed to the shocks). I'm not 100% sure, but I _think_ the longer springs go on the passenger's side (to counter the natural camber of the road in this country). I would say try it first, by installing the springs in the front and lowering the vehicle back down (without shocks and sway bar fitted etc, in case you're wrong). If you lower it down and it looks to be leaning too far in one direction, then try it the other way around.
Hopefully somebody else will come along with a more definitive answer for you.
Roachie
AnswerID: 321319
Reply By: oldpop - Tuesday, Aug 19, 2008 at 20:25
Hi Briann532
Longer springs always fitted to RHS to alow for torque reaction of engine and driveline
Oldpop
AnswerID: 321326
Follow Up By: Member - Madfisher - Tuesday, Aug 19, 2008 at 20:52
I presume you mean the drivers side?
Cheers Pete
FollowupID: 588166
Follow Up By: oldpop - Wednesday, Aug 20, 2008 at 06:42
Hi Madfisher
Yes Drivers side on RHDrive
and Passenger side on LHDrive
Oldpop
FollowupID: 588213
Reply By: pepper2 - Wednesday, Aug 20, 2008 at 12:46
I agree longer spring on drivers side on gu
AnswerID: 321398
Follow Up By: bbuzz - Friday, Aug 22, 2008 at 21:31
So is this true for all leaf spring jobbies? My 84 LC will need to carry a spare main leaf when I go so do I have to be careful what I take?
FollowupID: 588673
