Wednesday, Aug 20, 2008 at 19:18
Max, you are pretty
well right about aircraft
fuel quantity indication systems (fqis). I am a licenced aircraft engineer on all general aviation aircraft and also boeing 767s and 747s, and, although it doesnt help us here, its interesting (to some) anyway... most GA aircraft use a normal float system which as it moves, picks off different values of voltage or resistance, depending if its a potentiometer or a rheostat type. But boeings and airbus use a capacitance type. Its basically an inner and an outer metal cylinder where it measures the capacitance between the two. As the tanks empty, the height of
fuel between the two changes so the capacitance decreases and so the signal to the gauge changes. With this, the computer can create a linear quantity independent of
tank shape (programmed in), and also takes into account the specific gravity of the
fuel... higher SG means you have more weight of
fuel per volume...
As for this problem, if you really wanted to spend the time getting it right, the best solution would be to modify your float arm so it reads full scale- from empty all the way to full. Then get a variable resistor or calibrating box which can adjust voltages so that it sends the right voltage to your gauge so it reads correctly.
Once again i'm surprised that the manufacturer of the long range
tank doesnt supply something like this as part of their installation. After all, long range tanks arent cheap and a totally useless
fuel gauge as a result is pretty average really. I certainly wouldnt be happy after spending big bucks and having no idea how much
fuel i have when i need to...
588285
