01 GU Air Bag Light Flashing
Submitted: Thursday, Aug 21, 2008 at 00:09
Mike GU
Hi, I my air bag light has been flashing since i bought the car a couple of months ago, and i was just wondering if anyone has any idea about why it could be flashing.
I have a Temp and Boost gauge fitted just behind the wheel on the steering column (was fitted when purchased) and was wondering if the removal of the steering wheel could have affected the air bag or light/wiring? My mechanic says his diagnostic machine cant pick a fault and that ill have to take it to Nissan as they have one that might (that they wont sell to anyone).
Have checked all fuses and disconnected battery to re-set ecu but still no luck.
Thanks in advance
Mike
Reply By: Member - Paul C (NSW) - Thursday, Aug 21, 2008 at 00:45
Mike
Had a similar problem with a Magna and it turned out to be a dodgy sensor in the side airbag attached to the drivers
seat. Replaced under warranty with no further problems.
Not sure how removing the steering wheel would affect the light or warranty. Will Nissan know that if you take it in?
With the Magna, needed a "you beaut" machine from Mitsubishi to diagnose the problem in 10 seconds. Not sure if this technology was readily available to all mechanics.
Paul
321484
Reply By: Member - Rodney B- Thursday, Aug 21, 2008 at 13:33
Mike, my statesman was the same and they had to reset the computer to fix it. Only the dealer seems to have the reset ability.
321521
Reply By: Mike GU - Thursday, Aug 21, 2008 at 17:26
So the verdict is to take it into Nissan and get them to fix it? I was hoping that would be avoided as they will charge 100 odd just to plug it in to their diagnostic.
Thanks guys
Mike
321547
Reply By: rescue134 - Thursday, Aug 21, 2008 at 17:50
mike
don't take it to a dealer, check the fuse in fuse box, most common course that i have found. if that is ok your mechanic is able to read the codes and repair.
kevin
321551
Follow Up By: Mike GU - Thursday, Aug 21, 2008 at 18:35
have checked fuse and also mechanic diagnostic says no fault, dealer is only one left
588421
Reply By: mechpete - Thursday, Aug 21, 2008 at 18:05
normally when an airbag light comes on it means the airbag is diabled , so don,t have an accident .
321556
Reply By: ats11279 - Saturday, Aug 23, 2008 at 15:03
Mike,
yes the airbag light will come on if the steering wheel had been removed without disconnecting the battery 1st. The airbag system would have detected a break in the connection to the airbag, and disabled the system as a result. Some aftermarket diagnostic equipment can reset the system, but it would appear your mechanic's system doesn't.
Cheers Anthony.
321841
