Wheel size and Tyre question
Submitted: Thursday, Aug 21, 2008 at 21:01
Member - Porl
Well yes dumb question but I'd rather go to a dealer without needing to ask the truly dumb question.
My hilux has aftermarket
wheels and tyres, but these are different from the spare (damn). So I am trying to work out what size tyre I can fit on the
wheels. The spare is a 16" with a Bridgestone Dueller on it.
The actual
wheels on the lux are aftermarket alloys and the tyre markings are 31x10.50 R15 - now that tells me it is a 15" tyre, so question is, does that mean it's a 15" wheel which I'd find weird but then I can't find info that tells me if this tyre fits on what I hope is a 16" wheel so I can standardise with my spare.
Reply By: Member - Troll 81 (QLD) - Thursday, Aug 21, 2008 at 21:05
Yes it's a 15inch wheel if you had a 16 it will be something like 285X75R16
321599
Follow Up By: titl4 - Thursday, Aug 21, 2008 at 21:23
Maybe a 265 x 70R16 would be closer
588457
Follow Up By: Member - Troll 81 (QLD) - Thursday, Aug 21, 2008 at 21:57
I have a 285x75 on my 16's
588478
Reply By: Bonz (Vic) - Thursday, Aug 21, 2008 at 21:29
Theyre not 15" tyres, theyre 31" tyres on 15" rims. 31 x 10.5 R15 means 31" outside diameter, 10.5 inches wide R for Radial and 15 for 15" rims.
If your spare rim is 16" you'll need 265/75 R16 tyres which are also 31" tyres.
321603
Follow Up By: Member - Porl - Friday, Aug 22, 2008 at 08:08
Ok, so are we saying 265/75 R16 tyres fit on a 15" rim or are you saying if I want to standardise I got to get rid of the 4
wheels, or the change the spare, and the respective tyre/s.
thanks
588526
Follow Up By: Mark S (cns) - Friday, Aug 22, 2008 at 10:12
Porl
"Ok, so are we saying 265/75 R16 tyres fit on a 15" rim...."
No
"if I want to standardise I got to get rid of the 4
wheels...."
No
"or the change the spare, and the respective tyre/s...."
Maybe yes
Let me get this straight
You are happy with the current 4
wheels & tyres on the vehicle (with 15" rims) but want to make sure the spare is compatable with these 4 ?
If so, then Bonz gave you ther answer above.
The only thing that would stop you putting a 265/75R16 on your spare is if the spare is a skinny split rim. A 265/75R16 would most likely be too wide for this type of rim.
If this is the case, better off getting a second hand 15" rim and tyre that is the same as the current 4 on the vehicle.
Tried to keep it simple for ya, hope it helps
Mark
588544
Follow Up By: Bonz (Vic) - Saturday, Aug 23, 2008 at 08:36
No anywhere you see 14 15 16 17 18 19 20 etc thats the rim size
15" rims need 15" tyres
588708
Reply By: Towie - Friday, Aug 22, 2008 at 08:42
You have to stick with R15 or change all your rims to R16.. A sixteen inch tyre wont go onto a 15 inch rim..
When talking to the
shop man you want 265 width - 75 % of width as side wall depth and R15 is a 15 inch rim.... or take it in tell him to go look at it and measure it to see what will fit....
I recently found that a 305 tyre would go on my 16 inch rims which i thought impossible... they are the experts so let them work it out.... cheers
321666
Follow Up By: Member - Porl - Friday, Aug 22, 2008 at 10:04
OMG i bought a ute with a spare wheel different size to the rest of the four carrying me, now to find a rock to hide under and renew my
membership in a different name ...
588542
Follow Up By: HGMonaro - Friday, Aug 22, 2008 at 10:58
while the wheel my be of a different diameter (16" vs 15") withthe correct tyre you can still have the same overall diameter (or very close). Having said that, I'd be finding a 15" wheel and matching tyre.
588554
Reply By: Member - Philip S (SA) - Friday, Aug 22, 2008 at 11:20
Reply By: ExplorOz - David & Michelle - Saturday, Aug 23, 2008 at 15:49
Maybe a bit late responding to this but this resource will assist you -
Tyre Size Calculator
321849
