Caravan roof needs painting in Brisbane or Gold Coast
Submitted: Friday, Aug 22, 2008 at 08:22
ThreadID: 60976 Views:6044 Replies:2 FollowUps:4
Does anyone know where I can get a cheap roof respray in Brisbane / Gold coast area? We have a 1981 Jayco and the paint is peeling on the pop top roof and main roof. Its too big a job to do in my driveway with sanding back etc and but I don't want to spend a fortune. Being on the roof it doesn't need the prettiest finish, more a protection factor. Has anyone had caravan resprays and can recommend the painter?
Reply By: RONIN CRUZER - Friday, Aug 22, 2008 at 09:39
Hi David ,
You may not believe this but I have the exact same van / year and had the exact same issue.
I found that a light sand by hand , a full scrub down with methylated spirits with a ( you know very stiff brush scrubbing deck style ) , allow to dry and the self applied a good quality white acrylic spray ( spray can from auto store ) . This came up really nice and is still on , no flaking and is outside in the melb wheather 100% off the time . Holts make white spray cans of acrylic for vans but in little cans ( for touch ups ) and exspensive through carrvan accessory places. I also used a ladder and a long board to go across the van on the roof ridges.
AnswerID: 321680
Follow Up By: Member - David R (QLD) - Friday, Aug 22, 2008 at 09:59
Thanks Ronin.
If I end up doing it myself, I will follow your advice. I just think the extent of the flaking may be beyond the easy touch up stage. Also I'm a bit nervous about putting my weight on the roof which may break the old seals and give me a leaking roof.
FollowupID: 588540
Reply By: troopyman - Friday, Aug 22, 2008 at 12:14
Pay to get it sanded back some where then buy a 4 ltr of its so cool and the top clear cote . Put it on yourself with a roller and extention handle .
AnswerID: 321708
Follow Up By: Member - David R (QLD) - Friday, Aug 22, 2008 at 16:23
Thanks for the tip Troopyman. That might be the compromise between doing it myself and paying the big dollars for a pro job. The product you linked to looks good, probably not cheap but worth the extra being designed for the job. Being on the roof, I don't know if I need the clear cote, they say that is an aid to washing etc which is only a once a year job on the roof.
I would still be interested if anyone can recommend a cheap spray painter though.
FollowupID: 588607
Follow Up By: Member - Vince B (NSW) - Friday, Aug 22, 2008 at 17:45
Hi David,
I work at a smash repair business in South Tweed Heads.
Send me a MM as I am sure there are a couple of painters who would be interested.
Cheers.
Vince
FollowupID: 588629
Follow Up By: Member - David R (QLD) - Friday, Aug 22, 2008 at 18:01
MM sent.
FollowupID: 588632
