home made air operated washing machine
Submitted: Friday, Aug 22, 2008 at 12:44
mannrivermudrwestler
I was
camping at
Arrawarra and saw a bloke with a washing that ran off compressed air,!! he said he built it himself and he cleaned his clothes as he drove along as it ran off 12volt tyre compressor. it seemed to work really good , it blew bubbles of air into a plastic drum with a big screw lid, like the ones you get at the
camping shop for canoeing etc....., he said it didn't use hardly any detergent !, i think he had to change the
water to rinse but looked easy compared to those ones they sell at the
camping shows that you push up and down
I haven't seen one since, would like to find the plans to make one, if any one has found the site were he got the plans from
i was going to ask him about it ,but my wife shooed me away as she says i talk to strangers about
camping and she says its embarrassing
Reply By: Member - Alan H (QLD) - Friday, Aug 22, 2008 at 13:21
Sounds great.
We use those same plastic drums but no air just the bumps and corrugations on the road.
321722
Follow Up By: mannrivermudrwestler - Friday, Aug 22, 2008 at 13:42
does the bouncing along really work?
do you lye the container down in the horzitional?as i imagine you wouldnt get much aggatation in the vertical position ,as less surface area for the
water to sloosh about?
does it really clean them? as my wife is pretty fussy about washed clothes, espically for the kids, as she tells me i look like a homeless person ..go change your clothes!!
588579
Follow Up By: Member - Alan H (QLD) - Friday, Aug 22, 2008 at 14:09
Seems to
We have two of them held vertically in a frame on the A frame of the camper trailer. We do travel a lot when we are away.
Put clothes soap and
water in the container first thing in the morning. Lunch time wring them out and transfer them to the second rinse container. At
camp pull them out wring them out and string them up. (usually in
the desert or out west where they dry overnight)
I don't know about a perfect wash but
miles better than no wash.
If in the big smoke van
park etc would use other machines or laundramat etc mainly for bulk wash and to save hand wringing
An air operated spin dry would be the go!!!!
588585
Follow Up By: mannrivermudrwestler - Friday, Aug 22, 2008 at 14:31
I didnt get to see the nuts and bolts of this unit ,just heard it humming and asked what it was, don't know if it had a spin cycle in it ,but I suppose anything is possible these days I think i'm on my own here, unless I find a mad inventor or sciencest!!!
588589
Follow Up By: a convict - Friday, Aug 22, 2008 at 15:54
..great post mannrivermudrwestler
..bet it got a lot of us thinking
588604
Follow Up By: Mobi Condo - Saturday, Aug 23, 2008 at 07:54
Not sure about the bouncing along bit - we had our wash drum in action as we did the Davenport Ranges (NT) & Frew River Loop run.
The wash was no where as good as 200k on the Stuart Highway in a trailer!
I figured the higher speed micro vibrations through the trailer
suspension acted more like an UltraSound drawing office pen cleaner and we had lilliy whites (so to speak) when we got home.
Go - on laugh! Sounds like we still are waiting for the steak knife set and some dude to jump in front with a microphone!
But we still find highway vibes do better in the drum set up!
Cheers Mobi
588702
Reply By: Moose - Friday, Aug 22, 2008 at 15:03
You a big girl - letting your wife stop you talking to strangers:-) Hell if you only hang around with her you'll never learn anything new.
BTW - if this contraption blew bubbles in it must also have had an outlet - otherwise big bang!
Get yourself one of those that spin (manually) and you can sit there in
camp, away from other campers, and do the washing, and not embarrass your missus!
321737
Follow Up By: mannrivermudrwestler - Friday, Aug 22, 2008 at 15:53
very constructive reply!, thanks for your heartfelt response and articulate words of wisdom!.. if your in the
camp I'll be sure to be away from you!, no wonder your named Moose, is that your name or nature? seems your the one blowing all the air, you great lumox.
I don't think we need to read your I.Q level, for everybody to see in response to questions, as you haven't answered the question , just given a knee jerk response to a question that you obliviously can't answer due to your level of intelligence
save it for something that you might know something about ,.. but I seriously doubt this
oh by the way it had a srew lid, I'm shore it wasn't screwed on air tight,even a simlpton could work that out ,or was that part to hard for you to get through your "Moosehead'
588603
Reply By: RosscoH - Friday, Aug 22, 2008 at 16:11
The idea would work great, many years ago I did a shut down at a sawmill and we had to clean the delivery chains on the sorting table that were covered in years of wood sap and lubricating oil. Got an old 44 gallon drum and braised a piece of copper pipe with a heap of small holes drilled in it in through the side at the bottom so it went right across the bottom of the drum, put the chain in and filled the drum with with a mixture of kero and diesel and hooked the air hose up to the copper pipe with a valve so you could regulate the air flow and let it sit there and boil for a couple of days, the chain came out like new. It uses the air so there is movement in the liquid and it is not just sitting there soaking. Excellent idea on a smaller scale to clean your clothes, should have thought of that one myself.
Cheers Rossco.
321750
Reply By: Waynepd (NSW) - Friday, Aug 22, 2008 at 16:59
hey mann....etc,
I imagine you have to watch what soap you used, maybe a low suds front loader type would be fine. Otherwise the suds would be oozing out wherever the air vents to.
interesting idea though, have you googled it?
321756
Follow Up By: Pajman Pete (SA) - Friday, Aug 22, 2008 at 17:17
Looks like an Edwardian version of the little plastic pressure machines you can buy now - the ones with the handle you can spin.
Pete
588618
Follow Up By: mannrivermudrwestler - Friday, Aug 22, 2008 at 20:26
thanks for your resourcefulness guys, I don't know how I got through life without the handy helpers on
forum!
I'll just hook that one up to my horse & sulky!
Actually was looking for something invented within the life span of most of the people living on the planet
thanks anyway..
m.r.m.w
588660
Reply By: Waynepd (NSW) - Friday, Aug 22, 2008 at 21:09
m.r.m.w,
How long did he run it for? Most tyre compressors have a duty cycle which governs how long they can run before they cut out from overheating.
How big was the drum? 10l, 20l
I would wonder what type of washing was being done....could it handle jeans and/or shirts or maybe just singlets, socks and undies.
If you can get some plans or specs please share them, my curiosity is kicking in now.
321784
Follow Up By: mannrivermudrwestler - Friday, Aug 22, 2008 at 21:43
Wayne, I don't really know the details, as he was only around for awhile to stop and go, didn't get to eyeball that
well, he was a feral hippy dude in a clapped out old mini bus, all I remember he had tattooed tears under his eyes, had some heavy duty home-made tatts and a big brown dog as
well, think he was a ex-guest off her majesty, but he looked a very resourceful chappy!
the barrel was only maybe 50-60 litres maximum ,as he lifted it when it had
water in it. I am going to nut it out with bits and pieces in the shed this weekend as i got most off the stuff i think and easy access to the things i think i need
will post my sucess/failure in future
thanks
m.r.m.w
588675
Follow Up By: Waynepd (NSW) - Friday, Aug 22, 2008 at 22:00
OK thanks matee i will wait with bated breath.
588678
Follow Up By: turbopete - Saturday, Aug 23, 2008 at 09:35
and if the trucks exhaust was passed thru a barrell of clean
water (a scrubber) then into the washing the need for a compressor is eliminated,,wow this could be the start of something BIG
588716
Follow Up By: Waynepd (NSW) - Saturday, Aug 23, 2008 at 09:43
the exhaust could drive an old turbo to aerate the washing
water via an exhaust gas/
water heat exchanger which will warm it as
well......AH geez Pete now you're just getting silly LOL....
588721
Follow Up By: Member - Mick O (VIC) - Sunday, Aug 24, 2008 at 10:25
Jeez Wayne,
you boys have gotta get out more often : ) lol. My travelling mate has the best bush washing machine available. Capable of up to five loads in an afternoon although wash quality does drop off towards susnset. Very low maintenance, just on occassional back rub accompanied with words of encouragement and a glass of Baileys at the end of the wash cycle. Here's a photo.
Image Could Not Be Found
Cheers. Mick.
(P.S. Hows the Cobb going? Did you get the Thermal cover from Infront?)
588855
Follow Up By: Waynepd (NSW) - Sunday, Aug 24, 2008 at 11:52
ROFLMAO Mick.......yeh got a similar device here but its an older model. I noticed you picked the most attractive angle to promote the product too, good marketing strategy.
But from my experience I have noticed that as they age
They are harder to start, especially in the mornings.
They develop an incessant whine
and their intake of solid and liquid fuel increases too which in turn causes them to take up valuable room when trying to pack the truck for touring.
I have even had to resort to hand washing on occasion due to its excessive liquid intake.
I haven't tried the air-driven ones yet but it could be an option in the future.
If they could develop a silent, non-expanding model that only requires air to work i would trade
mine in for sure.
I haven't yet bought a cobb thermal, the bra is ok for me at this time, i did however buy a spare wheel garbage bag for fathers day....gee i spoil me
588874
Follow Up By: Member - Roachie (SA) - Sunday, Aug 24, 2008 at 21:00
Mick and Wayne..... Youz 2 blokes are either REALLY brave or REALLY stupid!!!!!! hahahahaha RAOFLMAO x 1000000000000 ( I hope for your sakes that your SWMBOs don't look at this
forum....)
588982
Follow Up By: Waynepd (NSW) - Sunday, Aug 24, 2008 at 21:14
Hey Roachie,
I have 30 years up in December, nothing scares me anymore LOL
Still that doesn't really resolve the brave or stupid question does it HAHAHAHAHAHAHHAHHA
588988
Reply By: mannrivermudrwestler - Sunday, Aug 24, 2008 at 19:01
guys just a short note that i got it too work, spent the w'end on it will have to do more R&R on it but it does work posted a new thread on Sunday after a few beers forgot to spell check as was in an altered state
322015
Follow Up By: mannrivermudrwestler - Tuesday, Sep 09, 2008 at 09:46
see site on goggle " egg washing machine" if it can wash what comes out of a chooks a!se it sure as hell can what comes out of yours
thanks to all who have a little faith
m.r.m.w
591578
