Sunday, Aug 24, 2008 at 19:00
Lyle,
Get yourself over to the
Nissan Patrol Forum where you’ll get all the info you’ll need to go about making the correct mods to your ZD30 Patrol.
Download this reference document by Patrol
Forum member aksniss. It’s a gold
mine of information and contains a section on blocking EGR.
I’m not sure what you mean about a one way valve, but if you’re referring to the ball valve on my
fuel filter housing, it’s there to check
fuel pressure and for bleeding. My
fuel system is fed by an electric pump at the main
tank, which supplies
fuel to the
water separator and the filter. The Walbro electric pump comes on with ignition and primes the system every time I start the car. I bleed the
fuel system after changing a filter, by fitting a small clear plastic tube onto the barb on top of the ball valve and putting it into a small jar of diesel
fuel. I then open the ball valve and turn on the ignition until air bubbles stop coming out of the tube, then just turn off the valve and remove the tube. Bleeding the
fuel system takes just a few seconds and because my
fuel lines are under pressure, there is no way any air can get into the
fuel system.
If you want to discuss anything off the
forum, you can email me at chaz at conody dot com.
Chaz
588939
