80 series chatter
Submitted: Saturday, Aug 23, 2008 at 12:28
husky01
just wondering if i can get some thoughts as to the origin of this chatter:
i have an 80 series GXL 1HZ with the part-time conversion fitted (ie: centre diff lock becomes 4wd button) HF2A transfer case
when in 1st, low revs, and foot off the gas (idling revs) it makes an obvious chatter noise. as soon as i speed up a bit it disappears completely, but take your foot off the gas (ONLY at idling speed) and it returns. revs over idling and anything up to highway speed it is perfect. no difference between 4wd or part time. No difference between high range or low range.
I am aware that (most) other older 80 series landcruisers have the same noise, and that it is sopposedly not a problem but i'd like to sort it out none the less. I figure its a common issue as I hear it in other vehicles at
the servo for example.
when walking over rocks in 4wd (foot off the gas), the noise is loud and comes and goes as the
wheels walk over the rocks.
front and rear diffs are perfect. no freeplay in shafts. no problems at all changing gears.
I suspect it is something upstream in the transfer case???
Any comments from others who have had the same noise????
Thanks in advance chaps.
husky
Reply By: Member - DOZER- Saturday, Aug 23, 2008 at 12:34
Husky, this is common on diesels that pulse when firing....some say it is the clutch springs and weights moving around, others say it is gear roll on in the gerbox, either way it is normal and cant be fixed...unless you buy a petrol or a duke box
Andrew
321829
Reply By: Member - 120scruiser (NSW) - Saturday, Aug 23, 2008 at 15:23
Worn damper cusions in the clutch plate.
A new clutch will fix it for awhile but it will return.
Clutch manufacturers have been trying to fix it for years with out success.
321845
Follow Up By: husky01 - Saturday, Aug 23, 2008 at 15:26
actually i did have a new genuine clutch kit fitted 12 months ago and interestingly it made no difference at all
588758
Reply By: husky01 - Saturday, Aug 23, 2008 at 22:34
cheers for the advice guys, appreciated
321895
