Friday, Jul 25, 2003 at 09:18
Powelly, sorry, I still haven't taken those measurements yet. I'll do it tomorrow.
Yes, I have reset the ECU. I actually did it several times while testing the Hiclones. I had enjoyed minimal improvements after trying several different positions for one, and the two Hiclones and the K&N filter so called John (Hiclone). Following that discussion, I reset the ECU and it made a marked difference. I then went through the entire testing exercise again, resetting the ECU each time, to finally arrive at the configuration I now have (2 Hiclones, at X and Y, and the K&N filter).
Resetting the ECU had a definite impact. I don't know if Nissan do this when they service the vehicle but it may be worth asking. I also reckon, from my experience, that you'd need to reset the ECU before changing
fuel types (std to premium or visa-versa) to gain any benefit. Swapping between std and premium every few
tank-fulls probably doesn't give the ECU enough time to "learn" and adjust settings to achieve the best results from whichever
fuel is being used. I don't think most folk realise that. I know people who put a
tank-full of premium in every so often in the belief that it helps clean/"tune" the motor.Smile, you're on ExplorOz
Rohan (
Sydney - on the QLD side of the Harbour Bridge)
17565
