Landcruiser alternator belts replacement.
Submitted: Sunday, Aug 24, 2008 at 10:37
desley
we have been quoted 2 - 3 hours to replace a worn alternator belt on our 100 series diesel. Thought it was excessive. Anyone know if it sounds reasonable ?
Reply By: BarraKing - Sunday, Aug 24, 2008 at 10:42
Hey desley,
Go some where else mate, workshop with the right
tools should only take 1/2 hr.
Josh
321951
Follow Up By: Top End Explorer Tours - Sunday, Aug 24, 2008 at 10:47
And that 1/2 hour should include their smoko break.
Cheers Steve.
588859
Follow Up By: Member - Doug T NT - Sunday, Aug 24, 2008 at 10:54
Steve
Location.....
Adelaide River
588861
Follow Up By: desley - Sunday, Aug 24, 2008 at 11:12
Thanks guys. This was a Toyota dealer. 2005 turbo diesel. Two belts on the alternator. Still same answer ?
588865
Follow Up By: Top End Explorer Tours - Sunday, Aug 24, 2008 at 11:16
I changed an alternator on my turbo in 1/2 hour.
Cheers Steve.
588867
Follow Up By: Member - lyndon K (SA) - Sunday, Aug 24, 2008 at 12:42
Steve, i have a TD Troopy, i did the aircon belt a while back,piece of cake. Re the fan belts,do any of the other belts need to be removed to change them or can the belts just be slid over the fan once completly slack?
588881
Reply By: Member - Doug T NT - Sunday, Aug 24, 2008 at 10:53
Why don't you do it yourself, better to learn at home than out in
the desert where you do it or die.
321953
Follow Up By: PeterInSa - Sunday, Aug 24, 2008 at 11:14
Agree with Doug, if you go bush on your own and have spare belts, better to know how to do it, and gain experience at home. Any problems you can call mobile mechanics
588866
Reply By: Member - DOZER- Sunday, Aug 24, 2008 at 14:16
To get them changed, you need to take off the air belt then get to the alt adjuster....it isnt a given that you will have the correct tools, but it isnt going to hurt to have a go in the driveway. Toyota dont make vee belts, so save extra by buying aftermarket...
I would take at a guess an hour to do the job....are the belts ratty or squeeling?? a simple adjustment only takes 5 minutes if they are squeeling....
Andrew
321971
Follow Up By: Member - Davoe (Yalgoo) - Sunday, Aug 24, 2008 at 14:35
actually dozer I think you will find it can be done with the crappy factory tool kit.
Just a tip or the unwary with the air con belt.
the nut running through the centre of the adjusting pully has to be undone before you can back the tension off to remove the belt
588891
Follow Up By: Member - DOZER- Sunday, Aug 24, 2008 at 16:18
I wont say impossible, Toyota have a pretty good selection of spannards, but that bolt your talking about for the air tensioner, which is 14mm....try undoing that with a Toyota openender...not impossible but easily rounded off...
The best mechanic to find is one which owns and drives a cruiser...cheaper than Toyota and probably better than their apprentices too.
Andrew hdft80
588919
Reply By: Member - Alan H (QLD) - Sunday, Aug 24, 2008 at 14:24
Change all belts at the same time and carry the "good" ones as spares. This way you know they will fit if required in the future and also know that next week you won't have another belt to replace.
321975
Reply By: Michael ( Moss Vale NSW) - Sunday, Aug 24, 2008 at 17:22
Desley.. Why not have a go at it yourself, i know it's not for everyone but its a good way to start learning something if you are not mechanically minded, maybe you are but choose not to do it. It also allows you to get a picture of how the front of the motor is laid out if you have a problem if you are out and about off the beaten track.. MIchael
321995
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Aug 24, 2008 at 17:23
OOOPPPS Sorry, others have said the same as I.. Michael
588922
