Patrol 3ltr with PROBLEM
Submitted: Sunday, Aug 24, 2008 at 22:03
ThreadID: 61048 Views:3193 Replies:10 FollowUps:7
Hi Everyone I have a patrol with a problem that Mr Nissan and others have no idea how to fix.
The problem with my 3ltr Manual truck is = Travel at 100ks at light throttle you feel a slight hiccup,then put your foot down on the accellerater no power,take foot off pedal then down again all the power is back.This can happen about every kilometre.this truck has been serviced every 5000 ks from new(2003) and has not any trouble previosly(120000ks)Any ideas would be a great help Cheers Baz
Reply By: Member - Mick O (VIC) - Sunday, Aug 24, 2008 at 22:45
May well be the Mass Airflow Sensor stuffing up. Be very careful. Try this Nissan Patrol Forum and you will get a knowledgeable response.
Mick
AnswerID: 322053
Reply By: TerraFirma - Sunday, Aug 24, 2008 at 22:48
Surely a fuel problem of some sort, pump, injectors, filter etc etc, shouldn't be hard to fix if you get the right people on the job. When you say Mr Nissan, who has worked on the vehicle.? If a Nissan service centre was it a senior mechanic.? Any smoke during the hiccup.?
AnswerID: 322054
Reply By: Member - Captain (WA) - Sunday, Aug 24, 2008 at 23:23
Hi Baz
What is happening is that the turbo is overboosting, the manifold pressure goes high so the ECU goes into a safe mode - you lose power. As soon as you lift your foot off the accelerator, the ECU resets and everything is fine.
Nissan do not know how to diagnose because the ECU does not record an error message (apart from the fact Nissan are pretty useless understanding the ZD30 motor).
The most likely cause of this is the MAF sensor playing up. Have you ever cleaned or replaced the MAF? I had a 2003 GU 3.0TD and it was very noticeable the performance improvement after a clean.
Captain
AnswerID: 322059
Reply By: Member - Andrew (WA) - Monday, Aug 25, 2008 at 00:24
I agree with previous replies..
Have you got an after market air filter in it or standard??? MAF Sensor is the likely culprit...replace it in a hurry.
If you have anything other than an original air filter in it, replace it with as well ASAP.
AnswerID: 322063
Reply By: Kiwi & "Grenade" - Monday, Aug 25, 2008 at 08:19
we have had similar problems.....it was with the fly throttle thingy...some sensor comes lose and loses connection....we have the engine light come on and have to pull over, turn car off and start it again.....had it to the mechanic and he has reset computer (but we did too and it slowed it down...)
we were told the mass air flow but it wasnt the case....
AnswerID: 322078
Reply By: redeye141 - Monday, Aug 25, 2008 at 18:37
Baz,
Had a very similar problem with mine. "Mick O" is correct the MAF was faulty. Replaced and all is well
Redeye
AnswerID: 322149
Reply By: hallmark1 - Tuesday, Aug 26, 2008 at 17:21
Hi Everyone here is update
Mick o
redeye 141 maf has been replaced no difference
Andrew WA filters all standard replaced every 10000 ks(sealed roads only)
Captain WAturbo boost at 16psi am told this ok???
Terra Firma Getting fuel system checked by expert but he tells me it seems ok
Kiwi&grenade had throttle position sensor changed when this problem raised its ugly head
Thanks every one Iwill let you know when we fix problem Baz
AnswerID: 322309
Follow Up By: Member - Captain (WA) - Tuesday, Aug 26, 2008 at 17:49
Hi Baz,
Hmm... not the usual suspect eh.
I still think its do to with the ECU thinking its overboosting, its the exact same type of symptom. Perhaps the pressure sensor is faulty? Your 16 psi is about right, but if the sensor is faulty and it "thinks" its say 25 psi, then you will get the exact symptoms you have, plus no error coded to show for it. Might pay to borrw a pressure sensor and see if it makes the difference.
Captain
FollowupID: 589302
Follow Up By: Member - Roachie (SA) - Tuesday, Aug 26, 2008 at 19:23
Gotta love all these fancy sensors......hahahaha (shaking head in despair.....)
FollowupID: 589328
Follow Up By: Member - Captain (WA) - Tuesday, Aug 26, 2008 at 21:04
Gotta agree with you there Roachie, chassis cracks are much easier to find!!!
mate
Captain
FollowupID: 589363
Follow Up By: Member - John (Vic) - Tuesday, Aug 26, 2008 at 21:20
Ooooo!! that was a low blow Captain LOL :-)
Got ya good with that reply Bill :-)
FollowupID: 589369
Follow Up By: Member - Roachie (SA) - Wednesday, Aug 27, 2008 at 19:38
Touche (or whatever that word is!!! hahaha).
But, at least with a cracked chassis, you see the problem and get it fixed....done.....finished (hopefully!!!).
With these damn air mass sensors and egr's and throttle sensors ad infinitim there are so many different possibilities. You change one thing, hoping that that is what's causing the problem, only to find out a few days later (cos it's intermittent) that you've spent $300- on a new sensor, but the problem persists.
No, give me a cracked chassis any day (well, maybe not really!!! hahaha).
Roachie
FollowupID: 589566
Reply By: hallmark1 - Wednesday, Aug 27, 2008 at 15:01
Hi Caption WA thanks for that reply Is the pressure sensor and the turbo sensor the same thing if so it has been replaced as well??????. Cheers Baz
AnswerID: 322467
Follow Up By: Member - Captain (WA) - Wednesday, Aug 27, 2008 at 15:34
Hi Baz,
Ok, looks like you have replaced the correct sensor. So far it looks like the electrics are working, time to move onto the mechanicals.
This sensor indirectly operates the diaphragm that moves the vanes on the turbo. If this diaphragm is not working correctly (or not receiving vacuum) then you still get the same symptoms. If you look at the turbo, you will see the diaphragm actuator has a small tube receiving vacuum to operate it. There could be any number of issues with this, blocked vacuum line, seized solenoid, seized diaphragm, seized turbo vanes etc... I would be checking that this diaphragm is moving to control boost pressure.
Captain
FollowupID: 589520
Reply By: Member -Dodger - Wednesday, Aug 27, 2008 at 15:44
Simple solution,
Trade the Grenade in.
Cheers Dodg.
AnswerID: 322473
Follow Up By: hallmark1 - Wednesday, Aug 27, 2008 at 20:16
captainWA thanks again will check tomorrow
Roachie not intermittent happened 73 +times in 70ks
Dodger to good a truck to get rid of
Cheers Baz
FollowupID: 589571
Reply By: hallmark1 - Thursday, Aug 28, 2008 at 18:22
Hi CaptianWA the local Nissan dealer has been in touch with Nissan Aust and guess what today came up wth almost word for word your diagnosis so have booked truck for Monday(The Service mananger is a mate of my sons and I must say he trying to have a go Will be in touch next week.Have appreciated your help so far. Cheers Baz
AnswerID: 322679
