100 series wheels
Submitted: Tuesday, Aug 26, 2008 at 10:47
ThreadID: 61095 Views:2222 Replies:5 FollowUps:2
hi guys
Can someone fill me in on the standard rim/wheel sizes on
100 series turbo diesel 2004 model.
I have 17 inch rims and just woundering if they are standard.
Reply By: Member - Graham H (QLD) - Tuesday, Aug 26, 2008 at 11:55
Well my 2005 TD has 16 x 8 factorysteel rims on it. My bosses 2003 Sahara TDhas 17x 8 factory Mags on it so I suggest you ring Toyota as some do and some dont but if they are oversize it will affect your speedo reading considerably
Use this comparator to see the difference Also gives you offsets and all
http://www.rims-n-tires.com/rt_specs.jsp
AnswerID: 322250
Follow Up By: Member No 1- Tuesday, Aug 26, 2008 at 12:30
my 06 td has standard 17in alloys
FollowupID: 589253
Reply By: Member - Graham H (QLD) - Tuesday, Aug 26, 2008 at 12:51
I think they changed wheel sizes in the May 05 update model
Mine is a Feb 2005 and is the first update, the May onward is the update of the update model
AnswerID: 322263
Reply By: Paul G K (vic) - Tuesday, Aug 26, 2008 at 14:14
The tyre placard on your car will tell you which tyres are standard.
AnswerID: 322280
Follow Up By: Member - Graham H (QLD) - Tuesday, Aug 26, 2008 at 14:18
It does but it also gives alternatives depending on rim sizes and the man wants to know if his are standard or not.
FollowupID: 589273
Reply By: Member - Prickle (SA) - Tuesday, Aug 26, 2008 at 17:59
We have a 2004 TD LC, purchased September, and has 16" rims.
Russ
Life-often hell but never boring.
AnswerID: 322315
Reply By: disco driver - Tuesday, Aug 26, 2008 at 18:32
If you really want to be 100% accurate, why not take your vin number to the nearest Toyota dealer and ask .
They should be able to verify all details on their 'puter network.
Disco.
AnswerID: 322322
