Where do you carry your gas bottle?
Submitted: Tuesday, Aug 26, 2008 at 21:50
Louie the fly (SA)
Hey all, when traveling, where do you carry your gas bottle? I don't tow a trailer when we go away, and I used to put it on the roof rack. But now with a smaller 4WD and no real roof rack (got one of those 1/3 length screwed to the roof thingos) we don't have that luxury. And the 1/3 length screwed to the roof thingo carries a canvas bag for bedding, tent & co.
Reply By: Member - GREENDOG - Tuesday, Aug 26, 2008 at 22:00
Louie it sounds like you are limited in carrying things,have you thought about buying a couple of single gas stove's that use the small gas cans if you know what i mean.cheer's GREENDOG
322368
Follow Up By: Louie the fly (SA) - Tuesday, Aug 26, 2008 at 22:13
Do you mean these Image Could Not Be Found That would be a good option with limited storage. How long does a can last? I'm taking Friday off to finish my rear storage unit. If I need to build in some storage area for a gas bottle I will but I'm sure it should be vented to outside.
589394
Follow Up By: Member - Olcoolone (S.A) The O - Tuesday, Aug 26, 2008 at 22:56
Don't buy one of them.
They are great for small amounts when there is no breeze or it is not cold.
We have one and it works OK if in ideal conditions but have a look at my favorite store Anaconda at the ones they have that screw onto a small round disposable gas bottle.
About 4 times the price but puts out about three time the heat.
589406
Follow Up By: PradoTrev - Thursday, Aug 28, 2008 at 11:40
With the small gas can , if it is cold put it in your sleeping bag and the gas will be warm in the morning. then as you boil th ater change canisters slow but it works.
Boiling the billy and hot
water 3 times a day and cooking bacon & eggs and dinner = 1 canister a day.
589654
Reply By: Richard W (NSW) - Tuesday, Aug 26, 2008 at 22:16
Louie,
Carried two 4kg bottles on the roof rack for the last trip but normally carry one inside the vehicle which I understand is not legal. I have the gas bottles with the safety valve so that even if they are turned on accidentally the gas will not be released unless a hose has been screwed into the outlet nozzle. Bit more expensive and you can't swap and go but much safer than the standard ones.
322374
Reply By: ingo57 - Tuesday, Aug 26, 2008 at 22:30
We carry 2 x 1.5 lt gas bottles in our bottom draw in the cargo area.
The inside of the draw is lined with carpet and the bottles have a layer of non slip rubber wrapped and taped around the bottles to prevent them banging together.
I always double check the valves are shut tight and bottles are tested regularly.
322381
Follow Up By: Louie the fly (SA) - Tuesday, Aug 26, 2008 at 22:41
I must confess, I've carried gas bottles inside the car on numerous occasions with no problems. Maybe I'm worrying about nothing. Tgough I might get at least 1 of those single burner jobbies. Rays Outdoors have them for $17. But I still need gas for my lantern, plus I have a single burner ring (don't be cheeky) that is great for boiling the kettle during the day.
589403
Reply By: MrBitchi (QLD) - Wednesday, Aug 27, 2008 at 07:59
Wouldn't touch one of those single burner things (as pictured above) with a 10' pole. They have a nasty habit of exploding. Was a thread about them a few months ago.
I carry a 2KG bottle on my roof rack and a couple of those Coleman .5KG bottles in the drawers in the back, suitable packed. No problems yet 8-)
322406
Follow Up By: Ozboc - Wednesday, Aug 27, 2008 at 09:12
yup , i had one explode on me .... had pieces of shrapnel fly past my head by just mm's and sounded like a bullet ricochet ....
best place for them is in the
shop where there sold -- not out
camping
Boc
589463
Reply By: Gazal Champion - Wednesday, Aug 27, 2008 at 12:08
Hi Louie,
I have 2 of these
camp stoves in the cruiser at all times. Even when away towing van. They are effected by breeze but you can use the lid as a wind shieild, even though they say not to. Never even looked like having a problem. Love em.
Wouldn't go without them, handyer than a shirt pocket mate.
Regards,
Gazal.
322452
Follow Up By: Gazal Champion - Wednesday, Aug 27, 2008 at 12:12
should have added that I have been using at least one of them regularly for 3 years now without a single problem.
cheers.
589501
Reply By: Member - Brian H (QLD) - Wednesday, Aug 27, 2008 at 15:28
I had three of them, one, a cheapie I had issues with in that the canister would not
seat correctly and I stopped using it as I figured leaking gas, flame, and big bang I can do without.
I now only have two and over three years have not had an issue at all. For me they are good for making a cuppa or making soup not for cooking steak etc.
I am looking at putting gas cylinder (4kg) under my tray and just use snap on fittings when required. Have to get the legal requirements first but this will solve my issue.
For finding a place in your vehicle the only issue I would have with gas cylinders is they are not always the same in size so be careful if making a space for the one you have your swap and go cylinder my not be the same size.
Brian
322470
Reply By: Patrolman Pat - Wednesday, Aug 27, 2008 at 18:47
I've used the small canister stoves for three years now and never had a problem. a gas bottle inside the vehicle should be vented but having said that I carry my oxy-acetylene in the back of the patrol all the time for work where the rear seats are.
322499
Reply By: Member - Barnesy - Thursday, Aug 28, 2008 at 02:22
Why not get an extra roof bar? A light weight rhino rack etc and put it on the other 2/3 of the available space on the roof?
Regarding those small burners, if you are thinking of getting something like this I would recommend a Trangia. They burn metho which is cheap, easy to buy anywhere and you don't have to worry about running out of fuel when
camping. You also don't have to worry about storage. They are designed for use in the Swiss Alps and still
cook when it's blowing a gale. A lot better than those cheapy, made in China, gas thingies.
Barnesy
322566
Reply By: Ron173 - Thursday, Aug 28, 2008 at 11:57
If your looking to store a 9kg, grab yerself a milk crate, fits perfect, then being square just fit in wherever, gives protection too, and obviously wont roll about.
officially milk crates remain the property of dairy etc etc.
Mine still belongs to the dairy, I just look after it for them.
Ron
322616
