Noise after water pump replaced
Submitted: Wednesday, Aug 27, 2008 at 09:29
Cram
Hi there,
I have a series 11 Disco TD5. I had the
water pump replaced last week and since then I have noticed a noise that I had not heard before coming from the engine bay.
Spoke briefly with someone and they said it could be a belt?
I can't get anyone to look at till tomorrow but was wondering if anyone had any ideas.
Reply By: Louie the fly (SA) - Wednesday, Aug 27, 2008 at 09:45
Hi Cram. Was the belt replaced with the new pump? Check the belt tension. If overtight or too loose it can make a noise. Overtight can be bearing noise, loose will be belt flap or squeal. Belt flap sometimes sounds like the belt is wet. I was taught as an apprentice that as a rule of thumb, belt deflection should be around 3/8 inch per foot of belt run with moderate finger pressure (bit hard to explain). Never use belt dressings on the belt, i.e. beltgrip, etc - if you need to there is a problem with the drive.
Cheers, Louie
322432
Reply By: Alan H - Wednesday, Aug 27, 2008 at 09:46
Hi Cram. You should ask that question on aulro.com as there's nothing they don't know about Landies there.
Cheers.
Alan.
322434
Reply By: Cram - Wednesday, Aug 27, 2008 at 10:01
Thanks for that I will check out aulro
322437
Reply By: Member - Rodney B- Thursday, Aug 28, 2008 at 11:11
Cram,
easy way to check if it is the belt is to put a hose on and dribble so
water on it and if the noise stops it's the belt.
322609
Reply By: Cram - Thursday, Aug 28, 2008 at 15:56
Hi everyone and thanks for your replies.
I have had the issue checked out and it seems to have been the fan belt and it is now hopefully sorted.
thanks again
Cram
322652
