Troopy Bush Camper. Top Bed arrangement. pics needed!
Submitted: Wednesday, Aug 27, 2008 at 20:58
ThreadID: 61140 Views:4056 Replies:3 FollowUps:3
Hi all,
I have just purchased a high top troopy bush camper and there are some parts missing. the sleeping area on top has no extension boards etc. can someone please send me detailed pictures so I know what to look for or make?
Kind Thanks
JAG
Reply By: Member - Bill F (VIC) - Wednesday, Aug 27, 2008 at 23:09
Hi Jag
Are you going to keep the hitop on now
There is normally 3 boards of marine ply that fit across the width and two foam mattresses that are stored above the cabin
we just use the bench and slideout extension that sits on top of the lift up bench with the cushion of the seat
Bill
AnswerID: 322554
Follow Up By: Fairlane - Thursday, Aug 28, 2008 at 07:00
Hi Bill,
I will be keeping te high top for now, with a view to change it when the time is right.
I would love to see how your set up works.
JAG
FollowupID: 589624
Reply By: stevesub - Thursday, Aug 28, 2008 at 09:48
I am away at the moment but our pop-top Troopy has 3 boards. The two that are closest to the front are joined by a hinge so they fold up when not in use. The rear board has a metal bar along the rear edge to help support it when a couple of heavy weights are up top.
There is also reinforcing between the rear most board and middle one. I will take photos when I get home on the weekend as it is a bit hard to explain the arrangement.
If you use thick enough ply or you are light weights, you will not need the reinforcing. The boards a re a tight fir side to side so they do not move around.
We prefer to use an air bed as a mattress as the supplied foam mattress (4 parts) is too thin. We cannot go thicker because being a pop-top and they are stored up top we do not have a lot of room with the roof down.
AnswerID: 322601
Follow Up By: Fairlane - Thursday, Aug 28, 2008 at 18:41
Thank you for your reply, hinged! that sounds like a good idea. I realy look forward to seeing your pictures.
Kind regards.
JAG
FollowupID: 589718
Reply By: Tim Owen - Thursday, Aug 28, 2008 at 21:06
I have a pop-top. Not sure how different, to hi-top re bed set-up. Set up I inherited has the boards connected by a couple of rails (from the underside), and there are a couple of posts which are used to 'prop up' the bed base up (one on either side) so you can still stand upright over the sink (but not down the front end of the car).
We have a 100mm latex overlay permanently up in the roof. Love it.
AnswerID: 322726
Follow Up By: Fairlane - Thursday, Aug 28, 2008 at 21:11
Thanks for that, any chance of a pic ot two?
my email is jgal3022@bigpond.net.au
JAG
FollowupID: 589768
