Daul Battery
Submitted: Wednesday, Aug 27, 2008 at 22:01
ThreadID: 61143 Views:2177 Replies:5 FollowUps:1
Looking at a 2006 STX Diesel Turbo cant see where you would put a 2 battery has anyone done this please.
Cheers Chuck
Reply By: Member - Chucky S (QLD) - Wednesday, Aug 27, 2008 at 22:02
Nissan Narvara
AnswerID: 322548
Follow Up By: Member - Mark G (NSW) - Wednesday, Aug 27, 2008 at 22:20
CHUCKY S
i think about the only way to fit in 2nd battery is to fit it up under the rear tray. i looked into this myself ( i have 2004 str) & your right there isnt much room under the bonnet.
i too will be interested to see where else you can put it, cheers.
FollowupID: 589606
Reply By: dave73 - Thursday, Aug 28, 2008 at 08:24
they make a tray to go on the inside of the chassis under the drivers seat. i was'nt really keen on that idea and have built a box to go in the canopy. they are a bit more expensive but gel batteries are the way to go when installing in the canopy.
AnswerID: 322583
Reply By: hotfishez - Thursday, Aug 28, 2008 at 16:31
The second battery can be fitted under the drivers seat bolted to the chassis. I think Phirana do the kit. We have fitted it to my mates STX. We used a gel battery, you need to cut a couple of mm off the small threaded battery terminals for extra clearance in the fully enclosed steel box. I was sceptical of this whole set up but doing the install and the way it has come up, I have no concerns with it. Good and soilid as any other arrangement.
THERE ARE NO PROBLEMS WITH THIS SETUP.
AnswerID: 322656
Reply By: Sir Kev & Darkie - Thursday, Aug 28, 2008 at 16:36
Chucky,
Have a look at this thread by Ross H he has an 02 Navara and incorporated the Dual Batteries into the tray staorage set up.
Cheers Kev
Russell Coight:
AnswerID: 322658
Reply By: Member - Marco T (VIC) - Thursday, Aug 28, 2008 at 17:46
Chucky,
i was quoted $2000 plus for custom set up under tray. I opted for an ABR sidewinder unit 'flyer' and remove it when not using it. I have mounted it in my tool box in the tray and have permanently installed the cables to suit. By removing the battery box you save the large weight when not in use. I installed the whole lot in 2 hours and spent @ $725 including 95 amp hr AGM battery.
AnswerID: 322665
