Oil filter oil catcher-1HZ
Submitted: Thursday, Aug 28, 2008 at 10:30
ThreadID: 61149 Views:4770 Replies:10 FollowUps:2
When changing the oil filter on my 1HZ (75 series) I lose a bit down the side of the engine. I've seen some 1HZs with a lip type catcher around the filter to catch the drips. Any ideas if they're a standard fitting or an accessory??
Reply By: Sir Kev & Darkie - Thursday, Aug 28, 2008 at 10:38
They stop the drips but then you still have to clean the residual oil spilt in them. I am going to modify mine to have a drain pipe down to the bottom of the sump.
I think they are a standard fitting.
Cheers Kev
Russell Coight:
AnswerID: 322606
Reply By: Member - Serg (VIC) - Thursday, Aug 28, 2008 at 11:35
Yep, it IS PITA – does not matter what you do, you still going to 5h1t yourself and engine bay with oil. I am wrapping rug at the filter base to minimize that pleasant effect.
Serg
AnswerID: 322612
Reply By: Vivid Adventures - Thursday, Aug 28, 2008 at 12:36
std fitting on all the1HZs I've owned.
AnswerID: 322620
Follow Up By: Member -Signman - Thursday, Aug 28, 2008 at 12:53
About 1/2 I've seen have, and others not.
Must have been if the 'Oil Filter Drip Catcher Fitter' on the assembly line was working on that day or not !!!!
FollowupID: 589655
Reply By: cowpat - Thursday, Aug 28, 2008 at 12:49
If you let the oil drain down to the sump overnight and change the filter the next day it will be empty and you will not spill so much oil. Yes there is a non-return valve in the filter but it's obviously not perfect.
You can still drain the oil when it's hot if you want - just don't forget to refill - maybe put the tub of oil on the front seat so you don't forget.
AnswerID: 322622
Reply By: Mikee5 (Logan QLD) - Thursday, Aug 28, 2008 at 13:18
Standard fitting on my 100 series 1HZ. When my vehicle was under warranty I took it to the big name Toyota Dealer near me for a service. Afterwards when i walked out of my garage I saw huge pools of oil on the driveway. On checking this drip tray was full of oil. Remembering this was a major Toyota dealer I got the s5its and rang them demanded they clean my driveway. Bottom line they coughed up $50 for me to do it. If Toyota can't get this right how can they be trusted on anything serious?????
Mike
AnswerID: 322624
Reply By: Member - Mark E (VIC) - Thursday, Aug 28, 2008 at 18:54
I've been battling this issue for some time, but the last time I changed the oil, I just accepted that it was going to be messy, so thought to get the filter off as FAST as possible. In doing so, I didn't spill a drop. Don't quite know how this happened, but am going to try again next time (though I suspect I'll end up with oil from ar$ehole to breakfast time).
Mark
AnswerID: 322685
Reply By: TD100 - Thursday, Aug 28, 2008 at 19:38
Signy
try toyota,you may be able to buy one for a 100 series with the 1HD-FTE as they have them standard. thats providing the 1HZ is mounted the same as the 1HD-FTE filter.i cant remember as its been a long time since i looked at one. cheers Paul
AnswerID: 322696
Reply By: Member - Ian H (NSW) - Thursday, Aug 28, 2008 at 20:37
Hi Signman,
Another way to reduce the oil spill is to punch a screwdriver point through the filter before removal to allow air in and oil out before you screw it off. I do it and it does help a lot.
Ian
AnswerID: 322715
Follow Up By: ross - Thursday, Aug 28, 2008 at 21:19
I wrap a rag around the base and most of the spillage gets soaked up by that.
FollowupID: 589770
Reply By: Rossco td105 - Thursday, Aug 28, 2008 at 22:38
G'day Signman,
Both my last two 1HZ 100series had/have it. Maybe, some of the 7* series missed out. Surely Toyota would have them...? may have to sit down for the price though. Can't find a part no. on the service CD but it's is called an oil receiver and shows up in a lot of schematics for the Toyota diesel engines.
Ross.
AnswerID: 322738
Reply By: oiler1 - Friday, Aug 29, 2008 at 08:30
I just figured out I did 70 oil changes on my HZJ80 and only ever put a rag underneath and let most of the sump drain first. Rarely got more than a bit of oil on the rags. Now I have a HZJ105R with the drip catcher and spill more oil than ever. It pools in the catcher and makes it harder to get a rag underneath. When I had a service at Toyota, they also didn't clean the drip catcher and I had oil down the side of the engine.
AnswerID: 322771
