Towing up the Toowoomba Range
Submitted: Thursday, Aug 28, 2008 at 13:43
ThreadID: 61157 Views:8369 Replies:13 FollowUps:8
Hi, just wondering if anyone has towed an Ultimate Camper (or similar - around 1 tonne laden) up the Toowoomba Range. We have a petrol Prado.
Reply By: Member - Peter R (QLD) - Thursday, Aug 28, 2008 at 13:47
We have the D4D Prado and it tows our 1.7t Jayco up the range no problem.
AnswerID: 322632
Reply By: Member - Mark G (NSW) - Thursday, Aug 28, 2008 at 13:48
FINDANOMAD
dunno about towing a camper up there but i drove up there the other day in a semi trailer. all i can advise is to hit the bottom and start changing gears. it was my first time up that way & boy o boy its steep!!
AnswerID: 322633
Follow Up By: Member - DAZA (QLD) - Thursday, Aug 28, 2008 at 14:54
Geez Mark
Was the truck empty or loaded? you would have got a bit of a surprise, doing it the first time, I used to drive up there on a regular basis years ago, when I worked for Gilbarco fixing Fuel Pumps from
Toowoomba out to Mitchel, I lived out of a Suit Case and stayed in
the Pubs, thats when I was single, with out a care and plenty of
hair.
Daza
FollowupID: 589674
Follow Up By: Member - Mark G (NSW) - Thursday, Aug 28, 2008 at 16:25
DAZA
gday mate, i was loaded going up.gross was 44 ton of steel for Wagners concrete.
FollowupID: 589691
Follow Up By: Kiwi & "Grenade" - Thursday, Aug 28, 2008 at 19:54
Hey Mark...Naths been trying to get a job with them...taking their time I tell ya...doesnt look like they got nothing for him...
FollowupID: 589735
Follow Up By: Dave(NSW) - Friday, Aug 29, 2008 at 14:28
Hey Mark, Tell your boss you need a bigger truck. A 550 Cat does it alright
Cheers Dave...
GU RULES!!
FollowupID: 589873
Follow Up By: Member - Mark G (NSW) - Friday, Aug 29, 2008 at 18:18
DAVE
it was a 550 cummins , signature at that, we carry the extra weight 'cause the trucks are mass managed,cheers
FollowupID: 589916
Reply By: Member - Andrew (QLD) - Thursday, Aug 28, 2008 at 14:24
Drive up the range all the time....with a KK and a diesel pajero.
You should have no problems, take it easy, there are two pull-over areas if you are worried.
The road surface has been fixed up recently and is in good condition, with speed limits reduced for all. (90km at bottom, reducing to 70km and then 60....helps control some silly manouvres at speed)
Andrew
AnswerID: 322641
Follow Up By: Member - Andrew (QLD) - Thursday, Aug 28, 2008 at 14:29
I should add that if you haven't been up there before, take a look at the Google Maps Streetview of the range....just like driving up it. :-)
Andrew
FollowupID: 589670
Reply By: Member - DAZA (QLD) - Thursday, Aug 28, 2008 at 14:44
We towed our Van up the Range a couple of months back, had no
problems, as said previously take your time, we did it with our
Nissan Navara that we traded recently, the van weighs just over
2200kg at times we dropped down to 2nd gear but all was ok.
Daza
AnswerID: 322642
Reply By: brushmarx - Thursday, Aug 28, 2008 at 14:46
No problems with a 3.5 petrol auto Monterey.
AnswerID: 322644
Reply By: Findanomad - Thursday, Aug 28, 2008 at 15:50
I'll give it a go and take it eeaassyy.
AnswerID: 322649
Reply By: Findanomad - Thursday, Aug 28, 2008 at 15:51
AnswerID: 322650
Reply By: wendys - Thursday, Aug 28, 2008 at 17:47
Defender 110 tdi and van, maybe 1.9 tonne - towed up the range a couple of times. Is a slow climb - but worse coming down!!
AnswerID: 322666
Reply By: Member - David R (QLD) - Thursday, Aug 28, 2008 at 18:33
Tip for driving up the range slowly: get behind a loaded truck in the left lane and stay there. Keep a respectable distance just in case, but that will avoid the temptation to push a little bit harder than you should and overheat or damage the transmission.
AnswerID: 322683
Reply By: 2TommyGuns - Thursday, Aug 28, 2008 at 21:09
Is it an auto or a manual??? If it's a manual just keep your revs in the sweet zone... Not lugging down low & not revving it's ring out. If it's an auto it should sort all that stuff out for you unless you want to play with manual selection but I see no real advantage in doing that, just take it steady & don't push it, if everything is in good order it will be a snack.
As an after thought with the auto, consider getting an after market tranny cooler just to cover all bases, doing the range on a hot day would test the efficiency of the tranny cooling system, also dragging the camper through sand would be a real challenge for it.
Cheers 2TGs
AnswerID: 322727
Reply By: oiler1 - Friday, Aug 29, 2008 at 08:23
I live in Toowoomba and tow a ski boat (1.5T) up all the time with a diesel landcruiser. Your petrol Prado will eat it! Be careful towards the top as the corners are blind and even at 60kmh if you are in the left lane you can come around a corner and find a truck doing 5kmh and you have to stop pretty quick. I always use the right lane going up or down in the 60 zone (this is legal) to avoid these situations.
AnswerID: 322769
Reply By: Member - David R (QLD) - Friday, Aug 29, 2008 at 09:32
You can actually avoid the steep climb but adds about 45 minutes to your journey. As you get through Ipswich, the highway divides between the Warrego, which goes direct to Toowoomba, or the Cunningham which goes a little south, signposted toward Warwick I think. The Cunningham joins up with the New England Highway a little ways south of Toowomba and you can get to Toowoomba that way without the steep climb. All good roads.
AnswerID: 322784
Follow Up By: Findanomad - Friday, Aug 29, 2008 at 09:39
I assume going this way you don't actually go as far as to have to go over Cunninghams gap as that would be just as steep as the T range?
FollowupID: 589843
Reply By: deserter - Friday, Aug 29, 2008 at 10:17
Why do people worry about hills on major highways that trucks go up all the time ??? I wouldn't even ask the question about a van unless it was some dirt road with extreme gradient and tight corners.
AnswerID: 322787
Follow Up By: Member - Old Girl (QLD) - Friday, Aug 29, 2008 at 13:54
Come on fellas there are some good points though.This fella hasn't seen it and is asking a simple question. We too live at the top and the only time there is trouble coming at you is in the wet dont sit behind slow trucks on the saddle as they do loose traction we know because its happened. The worst thing about the range is the down section and the bloody camera at the top.
If you are worried, it will do you the world of good to tackle it and learn to over come it.
FollowupID: 589870
