Winch hook storage
Submitted: Friday, Aug 29, 2008 at 14:34
Member - Alan H (QLD)
I have just acquired a new winch and need your expertise on storage of the hook.
I have seen some doubled back under the vehicle to a tow mount etc but this seems to put a very severe sharp turn in the cable.
What is the best storage location for the hook????
Reply By: Member -Signman - Friday, Aug 29, 2008 at 15:02
I've taken the hook off- replaced with a rated shackle (which you'd probably use most of the time anyway)- and fed it up to the fairlead under slight tension...
322815
Reply By: Redback - Friday, Aug 29, 2008 at 15:33
Mine sits in the fairlead
Baz.
322823
Follow Up By: Member - Mark G (NSW) - Friday, Aug 29, 2008 at 19:15
Image Could Not Be Found
same as
mine
589926
Reply By: P7OFFROAD Accredited Driver Training - Friday, Aug 29, 2008 at 16:12
mine hooks back to a tie down point, but it's not under tension...
It's just tight enough that it can't shake out, but I can get it out without backing out the winch if i have too.
---tried to insert the pic, but you'll have to cut and paste, sorry
http://picasaweb.google.com/chopperP7/GAMT1/photo#5230880409185903938
322831
Reply By: Member - Shane D (QLD) - Friday, Aug 29, 2008 at 17:55
I have my winch cable pulled in just like the above pic, however I noticted ALL the Army's L/rovers & unimogs that have
winches, have the cables loose with the hooks tied back with some light string.
The cables have no tension on them as the string they are using would only cope with the weight of the hook, There must be a reason why they have it this way, generally speaking, the Army does its research into such things.
Shane
322845
Reply By: Member - Alan H (QLD) - Friday, Aug 29, 2008 at 18:01
Thanks for all the ideas.
Guess that is the great value of such a
forum.
322846
