'07 CRD PATROL WHINING ENGINE
Submitted: Sunday, Aug 31, 2008 at 12:24
Heefers
G'day all, I have a bit of a whine coming from what is possibly the engine in my patrol. It is a 3.0 CRD Manual with about 15000k's on the clock. The noise kicks in when I bring the revs on and changes pitch and volume with more / less revs. The noise is there in neutral, in gear, clutch in or clutch out. Any ideas?
Many thanks in advance, Heefers
Reply By: Crackles - Sunday, Aug 31, 2008 at 12:51
Possibly alternator or idler pully bearing? It's still under warrenty so take her back to the dealer.
Cheers Craig.........
323113
Follow Up By: Goona - Sunday, Aug 31, 2008 at 22:05
Crackles,
Yeah good luck with nissan Warrenty. No such thing as far as I am concerned. Will go Toyota next time.
Goona
590262
Reply By: mark I - Sunday, Aug 31, 2008 at 13:17
Had something similar with my courier, thought it was the Turbo, ended up the exhaust manifold was leaking. Sounded like a bearing had gone.
323116
Reply By: Member - barry F (NSW) - Sunday, Aug 31, 2008 at 16:34
Tried going for a drive without the
cook?? LOL & cheers
323136
Reply By: Member - Olcoolone (S.A) The O - Sunday, Aug 31, 2008 at 16:58
Have you tried you Nissan dealer as it is still under warranty.
Asking a question like that on here is like asking Dazza down at pub whats the best way to invest $50,000.
323141
Reply By: Nav 8 - Sunday, Aug 31, 2008 at 20:16
I think you might find you have a blown gasket on the EGR pipe and loosing turbo boost, It is on the right side of the engine in the middle. It`s an alloy pipe with a flange top and bottom with two bolts in each one. You will probably find its the bottom one that has blown,it has a metal gasket and don't be surprised if a bolt is missing. The bottom flange will be warped and need facing up with a file before fitting the new gasket. Regards Nav.
323177
