caravan legs
Submitted: Sunday, Aug 31, 2008 at 14:54
ThreadID: 61257 Views:7201 Replies:5 FollowUps:0
I am sure I have seen a 12v tool for winding up (and down) caravan legs, have googled but nothing coming up. Anyone with info or ideas please.
Reply By: Member - DAZA (QLD) - Sunday, Aug 31, 2008 at 14:58
Hi Pippy
Seen a lot using Cordless Drills with a Attachment.
Daza
AnswerID: 323123
Reply By: Member -Dodger - Sunday, Aug 31, 2008 at 15:33
A cordless drill will do the job easily. I use an 18v Makita. Make sure you have it on the clutch setting as they will bite when the thread runs out on the leg. It is very easy for the handyman to make the leg winder fitting. For those without the type that takes a socket then it is a simple job to purchase a another winder and saw the handle off and use in the drill.
I'm lucky as my legs are the drop down type that can be operated by a socket fitting.
Cheers Dodg.
AnswerID: 323128
Reply By: Saharaman (aka Geepeem) - Sunday, Aug 31, 2008 at 17:45
Hi pippy62,
Have you considered installing an hydraulic ssystem like this one.
You can set all 4 legs and level the van in a few minutes from one position in front of van on drawbar. I have builders levels screwed to drawbar so you can level both directions (length and width) at once. Also hydraulic is easy to pull up legs - just release valves and they all come up in a few seconds. Hydraulics is also powerful enough to level van on a slope easily.
Image Could Not Be Found
Just a thought - makes life so easy to set up and take down.
GPM
AnswerID: 323153
Reply By: RoyHarvey - Sunday, Aug 31, 2008 at 19:38
Hi Pippy
You might also like to consider electric legs, see: http://www.autolegs.com.au/
We saved a big $'s on the listed price by picking them up in Adelaide.
Cheers Roy
AnswerID: 323168
Reply By: landed eagle - Sunday, Aug 31, 2008 at 21:31
I've a special tool for that part of caravanning. His name is Alex and he's 11.............don't think he'd appeciate being called a tool,but he does wield the winding apparatus with the diligence of an expert.
AnswerID: 323190
