diesel injectors
Submitted: Monday, Sep 01, 2008 at 14:08
Member - kevin Y (SA)
New to diesels
mine is blowing black smoke when i rev it a bit, i would say the injectors need work .
Anyone tell me of repairer around Elizabeth Sth Aus able to do the work
Reply By: howesy - Monday, Sep 01, 2008 at 16:07
It could also be something as simple as a dirty
fuel or in particular air filter as this can do this as
well. How much is it blowing when you rev it because thats what diesels do to a degree. Always start with the cheapest action take for assessment before you spend the best part of a grand on injectors.
323268
Follow Up By: Member - kevin Y (SA) - Monday, Sep 01, 2008 at 17:33
it has a new air cleaner , if it was white i would say rings , but enough black is coming out for me to worry .
fuel consumption varied on last 2000 km outing between 7 to 11ks per km no 2 fills gave me the same reading
590369
Reply By: Louie the fly (SA) - Monday, Sep 01, 2008 at 19:23
What kind of car Kevvie?
There is a diesel place on Churchill Road Kilburn that apparently does changeover injectors at a very reasonable price. Hitech Diesel Injection, telephone 8359 6088, Unit 1/418 Churchill Road Kilburn. No affiliation, never used them, but recommended by a few guys, including one from the trade.
Does your car have a screen type filter in the pump? If so it may be clogged.
323311
Follow Up By: Member - kevin Y (SA) - Tuesday, Sep 02, 2008 at 11:04
thanks for that ---not too far away will check them out
590518
Reply By: Thermoguard Instruments - Monday, Sep 01, 2008 at 20:12
Hi Kevin,
Are we talking about your '83 Toyota motorhome, as per your profile? (By the way, the poptop 'caravan' body looks great!)
As mentioned by others, diesels (especially older normally-aspirated designs like I assume yours is) do tend to pump out a good black haze when under heavy load. As long as it's not a thick cloud, I wouldn't worry too much. If the 156,000 kms is genuine, I shouldn't think the injectors would be worn out.
Before spending $$ on injectors, I'd renew all
fuel filters, drain and clean the sedimenter if one is fitted (and I'd expect one on a small truck like that). Then put a bottle or two of diesel
fuel conditioner/injector cleaner through it over a
tank or two of
fuel and give it a couple of long highway runs (a few hundred kms).
It's still seems too smoky then have a specialist check the injection timing and test the injectors on a test bench. Ones for that vintage of engine shouldn't be too expensive as they're a lot simplier than modern injectors.
For a bit of background reading on diesels, could I suggest
this article? There are also a couple of other articles on turbos and intercoolers in the Topics/Technical section of this website.
Ian
323319
