GQ Door latch mechanism
Submitted: Monday, Sep 01, 2008 at 14:22
Willem
AHHHH...I need some technical advice......
My inside drivers door latch does not open the door and the window has to be wound down to open door from outside which is a real pain.
Stripped the door down and have looked at the mechanics of it all from the inside. There does not appear to be anything that has broken so maybe it is just an adjustment which has to be made. Both outside and inside door latches work the lock mechanism though the inside does not activate it as far as the outside latch does.
I have looked at my
Gregory's Manual but it is inconclusive in its diagram and after an hour od Googling I still have not come up with an answer.
Are there any luminaries( or door latch techno's) out there with some advice?
Reply By: Kiwi Ray - Monday, Sep 01, 2008 at 15:25
Hi Willem
With the door open close the latch by hand
reach inside the door and operate the release cam at the lock to see if the lock is functioning.
If it is, it may be that the operating rod has been deformed
They are easy to bend back to the correct shape and length
Ray
323267
Follow Up By: Willem - Monday, Sep 01, 2008 at 17:42
Thanks Ray
I will see if I can get my hand in there...:-)
590371
Reply By: The Geriatric Gypsies - Monday, Sep 01, 2008 at 17:20
geez mate i am suprised somebody hasnt told you its because its a nissan and you should get a "toy "and thats all they arte
steve
323281
Follow Up By: Willem - Monday, Sep 01, 2008 at 17:43
Steve baby
I can see your lack of knowledge precludes you from helping out. Yer might know about electrics but zilch about door latches......hahahahahahahaha
590372
Reply By: Member - Axle - Monday, Sep 01, 2008 at 18:23
Willem, it could be worse!!, The outside one could have stuffed up..lol. Put the specs back on somethings just dropped off. trust me!! hahahaha.
Cheers Axle.
323293
Follow Up By: Willem - Tuesday, Sep 02, 2008 at 00:26
Thanks for your symnpathy, Axle!!!
I had the rear door outside latch break a while back. A
young fella here on EO found one for me in the Big Smoke and it was replaced.
Looking down into the cavities of the door is something else....lol
590479
Reply By: toyocrusa - Monday, Sep 01, 2008 at 20:38
Hi Willem. There is a
little spring that goes from the inside locking lever(which is operated by the snippet knob/rod from above) to the locking latch. This spring usually rusts and breaks. You may find pieces in the bottom of the door. If that is the case it may be easier to look at the L.H. side to see how it attaches. If it is the spring you can usually find some thing from Repco that you may have to cut and bend the ends to suit. Bob.
323332
Follow Up By: Willem - Tuesday, Sep 02, 2008 at 00:24
Thanks Bob
I will investigate a bit more as I don't see a spring marked in the diagram on the set-up. I will try to squeeze my arm down the inside oif the door...lol
590478
Follow Up By: toyocrusa - Tuesday, Sep 02, 2008 at 06:44
Hi. A telescopic magnet is an easier way of fishing around the door bottom. They are always handy if you drop something as
well. Available from a Repco/tool store. Regards, Bob.
590489
Reply By: Member - Barnesy - Monday, Sep 01, 2008 at 22:09
I had problem with my right rear passenger door with the outside not working yet the iside one did.
I found that the little rod connected to the handle, when you lift the handle it moves this rod which then moves a slider (behind the door lining close to the door latch) which is connected to a rod to the door latch.
This slider was jammed and not moving at all. So some CRC, a few minutes of wriggling the handle and dispersing the CRC had it working again. Not working 100% but it does open every time now.
Worth a try.
Barnesy
323367
Follow Up By: Willem - Tuesday, Sep 02, 2008 at 00:22
Thanks Barnesy...I will check it out in the morning
590477
Follow Up By: Willem - Tuesday, Sep 02, 2008 at 10:57
Thanks Barnesy. It is the slider which is broken. A Tek screw has fixed that.
590517
